  • 1994 - 1995 Specific Tech
What TKO do i have?
  • Thread starter Thread starter 94Blue302GT
  • Start date Start date Feb 19, 2006
94Blue302GT
704
Chicago
Feb 19, 2006
  • Feb 19, 2006
How can you tell what TKO you have? I bought one used a year ago, and didn't ask too much because i was getting it pretty cheap with the bellhousing etc. Was there a TKO before the 500/600? And how do i find out about gear ratio's etc.? It's 5 degree's (F) outside, so i didn't go and count splines, but could ya give me a rule of thumb? I"d like to know before i go and blow my T-5 this spring.
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Feb 19, 2006
  • Feb 19, 2006
Before the 500/600's, there were 3550's and tko's i think. But i dont know how to tell what u have though.
SVTCobra306
170
Ft. Bragg, NC
Feb 20, 2006
  • Feb 20, 2006
There should be a tag on it with the PN on it.
Mine's an early TKO500, still has 3550 on the tag then has I believe 4615 on it too. Mine's TKO500 with the 26-spline input shaft option.
You can look at the shifter too, go to Tremec's website for a picture of the shifter bolt pattern for a TKO500/600, it's different.
Also a 500/600 will have provisions for both electronic and gear-driven speedo's. I don't think the 3550/TKO/TKOII did.
94Blue302GT
704
Chicago
Feb 20, 2006
  • Feb 20, 2006
Thanks! Very helpfull!! Did you have any problems installing it? I hear you need a different driveshaft, which i don't currently have money for, crossmember either. And actually, i need to buy a clutch as well, which is what the money is dedicated for. I"ll have to check out the numbers etc. on it, just haven't had a chance to run out in the freezing whether yet.
94Blue302GT
704
Chicago
Feb 26, 2006
  • Feb 26, 2006
Well, i have a 26 spline input, AND the electronic and gear driven speedo's... i didn't see that tag anywhere, course, it IS in the back of my garage covered by a bunch of stuff at the moment, and there isn't any light over there. Kinda rebuilding my car.... at least it runs!
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Feb 26, 2006
  • Feb 26, 2006
as far as the input shaft, you should be able to just look at it and tell immediately if it is 10 or 26 spline. mine has a tag on the passenger side near the back (pretty much right in front of the shifter) with a part number on it. it is the number that looks like TCETXXXX. on mine it is on the bottom left of the tag. if you post that number, we can tell you what tranny you have right away.
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Feb 26, 2006
  • Feb 26, 2006
94Blue302GT said:
It's 5 degree's (F)
on a side note, its a very chilly 75 degrees here right now. according to this map, we are the warmest place in the country right now.....
sorry, just couldnt resist mentioning that.....
S351R"Animal"
20+ Year Stangneter
Dec 3, 2002
708
Manhattan, KS
Feb 26, 2006
  • Feb 26, 2006
Instead of replacing the driveshaft you can run a spacer.
94Blue302GT
704
Chicago
Feb 28, 2006
  • Feb 28, 2006
26 spline
TR 3550 2 ALJLC01 (?)
and on the tranny itself...
MSK11734
There were other numbers on the tag, but i had a hard time reading the ones i got. The guy painted it all blue.
still trying to figure out how the speedo works.
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Feb 28, 2006
#10
  • Feb 28, 2006
  • #10
it is the set of numbers directly under where it says tr3550.
94Blue302GT
704
Chicago
Mar 2, 2006
#11
  • Mar 2, 2006
  • #11
oh.. hmmm, it's pretty hard to read, i'll see what i can get out of it tomorrow.
Z
Progress Thread zeth194 - New Guy on the Block
  • zeth194
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 26, 2026
LILCBRA
D
Engine 85 GT Backfires through Carb
  • DienstXIV
  • Oct 3, 2025
Fox 5.0 Mustang Tech Oct 7, 2025
85GTStangGuy
new :poo: box, may need to hit you guys up for 79-82 info when i fix thIs turd.
  • rednotch
  • Sep 27, 2025
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 23, 2026
limp
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
VE Table Not Dialed? Send Me Your Datalog.
  • X-cam34
  • Feb 8, 2026
  • Digital Self-tuning Forum
  • 2 3
2K
Digital Self-tuning Forum May 1, 2026
X-cam34
