If you use Mark 7 rotors with spacers, then you probably won't be able to get any of the lugs on because the studs are short, and you will end up rubbing the outside of the fenders. So use '94-'95 spindles, '96+ will work but it moves the wheel out more (by about 1/4"), and will cause rubbing problems, especially if the car is lowered. '94-'95 Spindles keep the stock width.
I have '94-'95 Spindles in the front and the wheel sits almost perfect, it sticks out a little more than I'd like, but it's still under the fender for the most part, but thats just how the back spacing of the wheels are. The spindles have very short studs so I have just enough room to put the lugs on.
It doesn't matter what you use in the back, if you use ranger axles the rear wheels will look sucked in. I am going to run MM bolt on spacer in the back of mine to push the wheels out maybe 1.5"
Anything else?
