  • SN95 4.6L Mustang Tech
WHAT TO DO ...
  • Thread starter Thread starter ) y2kGT (
  • Start date Start date Oct 13, 2004
) y2kGT (
281
  • Oct 13, 2004
I am going to be putting some eibach sportlines on my car tomorrow and ordering my 295/35/18 tires tomorrow afternoon. Is there anything else i need/have to do other than installing the spring and mounting and balancing the tires? For example...LCA's ? CC Plates? Im a n00b to this all help is appreciated..
1low03gt
20+ Year Stangneter
May 24, 2004
708
11
38
Cold Hell,Ontario,Canada!!
Oct 13, 2004
  • Oct 13, 2004
I have the Eibach sportline springs aswell,you will deffinetly need C&C plates!
I got Maximum Motorsports 4 bolt C&C plates,and they work well.And i also installed their poly urethane front spring iscolater pads.
Then eventually you should invest in struts.The factory ones aren't that bad,but might not last that long.
The list could go on,off set rack bushings,bumpsteer kit,ects,...
White Stang
467
Ft Lauderdale
Oct 13, 2004
  • Oct 13, 2004
After you get the springs and tires installed post some pics I would like to see your pony's stance. I have the C-Springs uncut with 18-10.5 with 295 35 18 tires here is a pic of my cars stance.
) y2kGT (
281
  • Oct 14, 2004
Which tires will last me longer? Kumho Ecsta MX or Nitto NT 555...
the sizes im buying are 265-35-18 front; 285 or 295/35/18 rear.
One more question what do i need for suspension when i install my eibach sportline springs? Caster camber plates, struts, etc. or will i be fine just adding springs?
1low03gt
20+ Year Stangneter
May 24, 2004
708
11
38
Oct 14, 2004
  • Oct 14, 2004
You will need the C&C plates to get proper alignment!The rest can come after if you can't afford it all at once!!
XStanger
383
  • Oct 15, 2004
I have the sportlines and I don't have CC plates. I however left all of my spring isolators in, so I am not incredibly low. No uneven tire wear/alignment issues. 8000 miles so far.
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
R
Kenne Bell Supporting Mods for 2002 GT?
  • Rembrant
  • Mar 25, 2025
SN95 4.6L Mustang Tech Mar 25, 2025
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
