I have had a stiff clutch for the entire length that I have onwed my car, (since '97). I just thought it was a HD clutch. Wrong. Deff. a stocker. Well, about 3000 miles ago, it burnt up. I installed a Spec Stage II. When I put it in, the pedal feel was great. But when I went through the break in period, (500 miles in one night) it slowly started to get stiff. Like in the first 100 miles. I mean real stiff. Well, wouldn't you know, 3000 miles later, I burnt up that clutch. This time, the burnt clutch was completly my fault, with a poorly adjusted aftermarket quad.
Now I am replacing every part associated with this clutch. The aluminum bearing retainer has some stepped grooves wore. But when I changed the first clutch, they were no near this bad. So I'm thinking this could possibly have caused the stiff clutch, but I'm not sure, because the grooves were not this bad before, yet the pedal was hard. The cable is a stocker, and moves freely. No binding, heat markings, or fraying. It is still getting replaced with another Ford stocker. I am thinking possibly clutch fork/pivot ball. What should I look for with this?
Also, when I took the bellhousing off the last time, one of the mounting ears broke. It is only the top half, but this whole situation has me looking at every part with suspicion. Could this have anything to do with this. I mean, all the botls line up and torque fine, no binding. Also the ear is still sitting right with the dowel pin on both sides.
Here are a few pics of the bearing retainer. Any ideas?
