What to lubricate wrist pins with?
Saleen302
30
Los Angeles, CA
Stock rods bushed for floating pistons(SRP)
What should I lubricate them with? Engine oil, assembly lube?
The directions from SRP say to use "lubriplate" or assembly oil. What is lubriplate? Is assembly oil different from either assembly lube or motor oil? Please clarify. Thanks.
just use a good REGULAR oil. just lube the side skirts, wrist pin, ring real nice, cylinder wall, and any other part where there is metal to metal, lube with good oil ;)
Lubriplate is a white, lithum based grease used for assembly and general purpose lubrication. I have used it for years on everything from aircraft engines to Tremec transmissions. Works great, and I have never had any problems using it.
