  • 1994 - 1995 Specific Tech
What Transmission?
  • Thread starter Thread starter doobsstang
  • Start date Start date Jul 12, 2006
doobsstang
92
Pembroke, NH
Jul 12, 2006
  • Jul 12, 2006
My AODE is crapping out on me and I am going to put a manual tranny in. I am wondering which tranny will be the best for it. Not sure about putting a T-5 in since I plan for a lot of mods and a lot more hp so which would be the best? Thanks.:SNSign:
Blackened302
1,439
South TX
Jul 12, 2006
  • Jul 12, 2006
tremec, at least, like a 3650, tko-500 or 600
def stay away from the t5! (unless you buy one of those new rebuilt ones that just came out)
doobsstang
92
Pembroke, NH
Jul 12, 2006
  • Jul 12, 2006
i like the tko-500, i am pretty familiar with a t-5 swap, what are the differences when putting in a tko?
9
95vert354
107
  • Jul 12, 2006
Different bellhousing and drive shaft yoke,longer driveshaft,and adjustable upper control arms
bimmertech
1,123
merriam, ks
Jul 12, 2006
  • Jul 12, 2006
t56
doobsstang
92
Pembroke, NH
Jul 12, 2006
  • Jul 12, 2006
I have been looking at some kits at D&D Performance. Are their kits good? I have heard some good things about them and wondering if they are reliable. Not sure whether I am going to swap in a TKO-500 or T56.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Jul 12, 2006
  • Jul 12, 2006
what the hell do the control arms have to do with the swap????
I have seen people beat the hell out of the t-56 and it lives to tell the tale. A few people here have the 500/600 and it has done well. IDK what I will do when the time comes, I am between the two right now.
Scott
9
95vert354
107
  • Jul 12, 2006
Scott
It lets you adjust the pinion angle, to get rid of the high speed vibrations that most people have a problem with when doing the TKO swap. I guess you never saw those threads before?
bimmertech
1,123
merriam, ks
Jul 12, 2006
  • Jul 12, 2006
i have the d&d T56 in my car and i find it to be a great tranny.
shifting is smooth, fifth gear is actually useful, and it has handled everything i have thrown at it.
you will not be disappointed in the T56.
HGFireHazard
460
Michigan
Jul 12, 2006
#10
  • Jul 12, 2006
  • #10
I always see a lot of votes for the Tremec trannies like the TKO and such, but how about for those built up G-force T5s? They seem to be able to handle similar power to the TKO and have some nice features and upgrades to them as well. Especially for the freeway cruiser they come standard with a .59 ratio overdrive. Anybody running a g-force here and like to give us some insight?
BDAWK2002
139
Old Bridge N.J.
Jul 12, 2006
#11
  • Jul 12, 2006
  • #11
TKO is a great trans.Only problem is no one has really figured out the high speed vibration yet.
Blackened302
1,439
South TX
Jul 13, 2006
#12
  • Jul 13, 2006
  • #12
read above
9
95vert354
107
#13
  • Jul 13, 2006
  • #13
I have See page 4, TKO install problems http://forums.stangnet.com/showthread.php?t=625518&page=4
Pokageek
2,767
MA, USA
Jul 13, 2006
#14
  • Jul 13, 2006
  • #14
UM..give this guy 1000points! I have been wondering about this for a long time and did not see this on any former threads.
In case anyone missed it. Vibration problem answer: Different bellhousing and drive shaft yoke,longer driveshaft,and adjustable upper control arms
p.s. "different drive shaft yoke" = ? Thanks.
eagleautosports
139
Mebane NC
Jul 13, 2006
#15
  • Jul 13, 2006
  • #15
G Force gives you gear ratio options where Tremec doesn't. Plus with the G Force you don't have all the install headaches. It'll bolt right in just like a T5 and it's lighter than the Tremec. Slider options are there too if you wanted one for the street, drag or road racing. Check them out.
9
95vert354
107
#16
  • Jul 13, 2006
  • #16
When you buy the kit ,it comes with the correct yoke and Tremec bellhousing. I got mine at http://www.mustangsunlimited.com/Default.asp
Good prices, great customer service, and the best shipping and packaging I've seen yet
doobsstang
92
Pembroke, NH
Jul 13, 2006
#17
  • Jul 13, 2006
  • #17
I looked at the G-Force and say that I am quite impressed. What gear set is good to get? Any difference in bellhousing? I like that it has .59 gear ratio for O/D. I am assuming that installation is the same as a regular T-5 swap. If not can you let me know what is different. Sorry for all the questions. I am just ready to get the AODE out of there. Thanks :SNSign:
eagleautosports
139
Mebane NC
Jul 14, 2006
#18
  • Jul 14, 2006
  • #18
I'd say talk to G Force and see what they say because I don't want to steer another gearhead wrong. Physically, it'll bolt in just like a regular T5, not like a Tremec that needs a different yoke, crossmember and so on. The bellhousing should be the same, just go with a good aftermarket and a good clutch.
Blk91stang
607
North Brunswick, NJ
Jul 14, 2006
#19
  • Jul 14, 2006
  • #19
G-Force here and It is a pretty stout tranny. I have no had the opportunity to really beat the snot out of it but it has great street manners and shifts very nicely. Only complaint is when the tranny is cold (below 45 degrees), it grinds into some gears until it completely warms up (5-10 min of driving), than it shifts like a warm knife through butter!
Easy installation too, pull the stock one out, put the new one in. Done!
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Jul 14, 2006
#20
  • Jul 14, 2006
  • #20
After I posted this, I started thinking about that. But I haven't paid much attention to those threads b/c I am a ways away from affording a new trans...and to you sir, I say
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
What megasquirt kit to order
  • 74delta
  • Jul 4, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 26, 2026
fasterthangas
F
AOD TV linkage
  • Titanium90
  • Jun 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2025
KRUISR
