What would cause an intermittent lean condition?
BigHairyMonkey
411
Houston (Bellaire) TX
Usually the car would only do this when it was cold, but lately it has started to pick up in frequency. My car is really moody part throttle... sometimes it runs great and has amazing throttle response, but sometimes as im driving ill start feeding it gas and itll start bogging down; as if its not getting a reading from my right foot. Today it happened REALLY bad, usually it happens for a sec or two and clears up but today as i was driving i shifted into 3rd and got into it about 20% it started bogging... i gave it 30%.. no differene i shoved my foot into it about 60% ( i get some pops outa the intake manifold as i guess its running lean)..nothing then all the sudden like a light switch, BAM shoved in my seat and the car takes off like normal??! The car runs like a raped ape at WOT but at part throttle it seems like the power/throttle response comes and goes. What could be the culprit?
-02 sensors have less than 4 months on them
-IAT less than 2 months
-IAC less than a month
-ECT less than 2 months
-Only old sensor on the car is the TPS. (but it is set @ .99 at idle)
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
attachment.php
attachment.php
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
See the "Surging Idle Checklist for help with all your idle/stall problems. The first two posts contain all the updates to the fixes. I continue to update it as more people post fixes or ask questions.
