what would cause this?
  • Thread starter Thread starter brycew
  • Start date Start date Dec 29, 2006
brycew
15
  • Dec 29, 2006
my car idles fine until after 30 mins of driving. after that in drive the idle shows 900 instead of 6-700 and in park jumps up to 1300 and settles to 1000. while i am driving the gas pedal feels different every time i press it. what would cause this????? i have replaced egr, iac, tp, ect, spark plugs, rotor, dist cap, wires, intake manifold gasket, tranny filter service, throttle body is clean and have reset base idle vacuum is at 17 at idle and fuel pressure is 35. this is an 88 mustang gt aod and speed density. any help would be appreciated running out of ideas for things to fix
T
Teknik
106
  • Dec 29, 2006
Could be something mechanical and not electrical. Check the throttle body
blade, return spring, throttle cable. Mabey they work fine when it's cold
but don't when they warm up. Could also be something else stupid that
you overlooked , like the vacum Modulator on the tranny. I had an AOD
once that did all kinds of wierd stuff after it warmed up. And it ended
up to be the vacum modulator.
Hope you figure it out!
Oh, O2 sensors and BAP sensor could be checked out though !
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 29, 2006
  • Dec 29, 2006
You guys with idle problems could same a lot of time chasing your tails if you would go through the Surging Idle Checklist. Over 50 different people contributed information to it. The first post has all the fixes, and steps through the how to find and fix you idle problems without spending a lot of time and money. I continue to update it as more people post fixes or ask questions. You can post questions to that sticky and have your name and idle problem recognized. The guys with original problems and fixes get their posts added to the main fix.
brycew
15
  • Dec 29, 2006
where is the vacuum modulator??
T
Teknik
106
  • Dec 29, 2006
It's on the Tranny. You can follow the vacum line from the back of
the engine down. It should be goldish.
brycew
15
  • Dec 29, 2006
well found out that there is no vavuum modulator on my car solves that issue.now leaning towards tv rod because when d-accelerating it gives a quick rev on the downshift almost like the aod clutch is catching
superhuaman
907
Harrisburg, PA
Dec 29, 2006
  • Dec 29, 2006
aod's dont have a vacuum modulator
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
Engine Surging idle on start-up
  • keel
  • Aug 11, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
keel
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
F
Resolved Stumble issue upon acceleration (1987 GT)
  • FoxDude87
  • Sep 16, 2024
  • 2 3
4K
Fox 5.0 Mustang Tech Dec 3, 2024
FastDriver
