What would you change on a fox body?
MAC'n89Blckstng
1,012
NJ
I'm bored and I was thinking about all the things I wish ford did to the fox body to make them "better" from the factory.
Stronger trans than a t5
An easier way to get the shifter out (I gotta fenagle a wrench to get the two front bolts out)
electric fan!
5 - lug!
and cupholders.
What do you guys have in mind?
Better trans ( I have to drop my T5 just to get the shifter off since the T-5 didn't come in 79s so the hole is offset differently)
big disk brakes all around
bigger wheel wells that will hold 335s on the rear and 275s on the front without rubbing
sub frame connectors
coil overs
I would have to agree.
Trans stronger.
4 wheel disc brakes, and a little bigger up front.
AND... subframe connectors standard.
Hydrolic Clutch instead of cable.
Same motor, but the 351W standard.
I think instead of the SN-95, they should have made the 93 Cobra the standard GT.
one thing cosmetically that has always kind of bothered me is how the window "line" from the side view mirrior to the back point of the 1/4 window slopes down rather than with the flow of the rest of the body. i think it would make the car look more aggressive if it was like i said
What everyone else said....
plus they should have all looked like this:
