tony laq said:
just checked the flowmaster site and didnt see 10's. am i missing something? damn a loss of ANY hp/ torque isnt what i want right now...maybe the pullies are a better idea..if so i can afford somthing else too..they are as much as the other stuff
It seems beyond popular belief that a flash tuner would not be a
first choice, including me, but if you want to get the low-end back that you lose from a free flowing larger diameter exhaust, the turner will do it. I went with exhaust first, then the tuner and then a gear change. I didn't feel a lot of difference with the exhaust down low or up top but I felt the tuner's effects on the bottom end and mid-range the most right away.
Also the tuner smoothed out the way my Mustang would rev up during normal driving and WOT. It even gave me a little increase in gas mileage, I fill up my car and check this everytime with a spreadsheet I made for keeping up with it.
It was nice to already have the Predator when it came time for my gear changes too, it made that a simple plug and play fix of the speedo.
Some more benifits I used from the Predator for is the ability to change my rev limiter, which I lowered from 7200 to 7000 for an extra measure of safety incase I missed a shift or got too happy with the throttle taking off and free spinning the tires to the rev limiter. I also was able to turn off my traction control which sometimes I forgot to do manually and was able to turn off the speed limiter which I really didn't need too but hey, it was there so I did.
I was able to adjust my idle down 50 or so rpms because I felt 800 rpms was too much.
I haven't messed with the timing advance or richening up the fuel mix yet using the tuner but I hear a lot of talk about it's advantages and performance improvements.
Good luck in your choice(s) of your what to do's, I know it's tough with all there is to do to the Mustangs and the aftermarket stuff available. It looks as though you are getting some very good advice from these guys replying to your post too.
EDIT: oh yeah, one other thing, I was able to change my fan on and off settings to improve my cooling and keep the temperatures at a more constant state than the factory settings using the flash tuner.
