what would YOU do?
thanks alot for the opinion guys! i wasnt aware that a mid pipe would cost me something down low, which sucks. i really dont race and its rare that the car goes over 4100 rpm or so. so top end really isnt a concern for me.
im not going O/R because of local laws..i just dont feel like dealing with emissions and cops.
i was under the impression that a mid pipe with stock everything else would just pretty much drop the tone a bit in addition to making it a bit louder. the only mods ive done so far is a FIPK II and an MGW. so as you can see i just gettin' started. its a 2002 gt stick.
-tony
-tony
If you aren't ditching the stocker mid pipe, get Flowmaster 10s (the racers) and you will be pleased.
:banana:
with a catback or H pipe you may pick up 1-4 top end hp but will lose torque.
If your looking to make your car quicker Id vote for 4:10 gears or the Steeda U/D pullies. A programmer should be the last mod you purchase so Ive been told.
If you are going for looks in the engine area then maybe the c&l with a bbk CAI would look good and gain you about 4-7rwhp.
just checked the flowmaster site and didnt see 10's. am i missing something? damn a loss of ANY hp/ torque isnt what i want right now...maybe the pullies are a better idea..if so i can afford somthing else too..they are'nt as much as the other stuff :D
tony laq said:
just checked the flowmaster site and didnt see 10's. am i missing something? damn a loss of ANY hp/ torque isnt what i want right now...maybe the pullies are a better idea..if so i can afford somthing else too..they are as much as the other stuff :D
It seems beyond popular belief that a flash tuner would not be a first choice, including me, but if you want to get the low-end back that you lose from a free flowing larger diameter exhaust, the turner will do it. I went with exhaust first, then the tuner and then a gear change. I didn't feel a lot of difference with the exhaust down low or up top but I felt the tuner's effects on the bottom end and mid-range the most right away.
Also the tuner smoothed out the way my Mustang would rev up during normal driving and WOT. It even gave me a little increase in gas mileage, I fill up my car and check this everytime with a spreadsheet I made for keeping up with it.
It was nice to already have the Predator when it came time for my gear changes too, it made that a simple plug and play fix of the speedo.
Some more benifits I used from the Predator for is the ability to change my rev limiter, which I lowered from 7200 to 7000 for an extra measure of safety incase I missed a shift or got too happy with the throttle taking off and free spinning the tires to the rev limiter. I also was able to turn off my traction control which sometimes I forgot to do manually and was able to turn off the speed limiter which I really didn't need too but hey, it was there so I did. :D I was able to adjust my idle down 50 or so rpms because I felt 800 rpms was too much.
I haven't messed with the timing advance or richening up the fuel mix yet using the tuner but I hear a lot of talk about it's advantages and performance improvements.
Good luck in your choice(s) of your what to do's, I know it's tough with all there is to do to the Mustangs and the aftermarket stuff available. It looks as though you are getting some very good advice from these guys replying to your post too. :nice:
EDIT: oh yeah, one other thing, I was able to change my fan on and off settings to improve my cooling and keep the temperatures at a more constant state than the factory settings using the flash tuner.
+1 for a mid pipe...if you dont have emissions where you live go the cheap route and pick up a o/r upr x pipe and have some mufflers (insert brand of choice here) and have them welded in if you can't afford the whole catback..will yield decent gains and help give your stang some sound..
thanks alot for the info guys..ive never had a car i wanted/ could mod so this is all really new- also tough to know what to do when a local shop tells you a plen/tb will give you " about 30rhp" ..i wouldnt have know that was wrong if it wasnt for this site so thanks again. :hail2:
as for gears, im a COMPLETE wuss..for some reason im just dead set against them ( for now at least). i really dont race and i like the way the car drives stock..for some reason i have a feeling that even 3.73's would some how screw up my car or the way it drives. anyway....
thanks again for the great info guys!
tony
Hotrodnut 7000RPM ?????????
Tony gears won't mess anything up I went 4.10's and love them (well actually kinda think I should have gone 4.30's but I want to FI in the future) if you cann't or won't do them have someone who does put them in. I didn't mention it because it wasn't one you listed. The plus if you do normal around town driving and normal flow of traffic driver your in the powerband more often. Lots more fun. Also if you haven't thought about it a set of subframe connectors are a great building block upgrade. The order I went was MGW, C&L inlet(gift), k&n, subframes, P&P stock upper, gears(4.10) dallas mustang to correct speedo. IAC blockoff cause I hated the hanging rpms.
