  • 1994 - 1995 Specific Tech
WHAT would you do?
  • Thread starter Thread starter DDSTANG94
  • Start date Start date Dec 3, 2008
1 of 2 Next Last
DDSTANG94
465
FRASER, MICHIGAN
Dec 3, 2008
  • Dec 3, 2008
ok, dont no if this is talk or tech?
Ok so i have waiting to be installed, AFR 165's, a FTI custom cam, longtubes..ect...I had the cam ground for the a edelbrock rpm 1 intake, But i think i want to make a change, HEAR ARE MY THOUGHTS/OPTIONS ..H/C/I peeps gimme ur thoughts.....
OPTION #1 keep the rpm
OPTION #2 get a PP typhoon intake and have TMOSS PORT IT
OPTION #3 Holley systemax II
im leaning twords option #2, but i heard the qualtity is poor and that maybe the preformace is poor on them? anythoughts?
Also option #3, but i dont want the low end to suck, BUT i did have the cam ground with low end in mind so it might not be that bad?
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Dec 3, 2008
  • Dec 3, 2008
Systemax II. The intake isn't going to effect what kind of cam you use that much.
Kurt
ProKiller
3,064
15
78
PA
Dec 4, 2008
  • Dec 4, 2008
i don't think option 2 is an option. Tom can port the performer
vladasap
294
nyc, ny
Dec 4, 2008
  • Dec 4, 2008
EXACTLY !!!
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Dec 4, 2008
  • Dec 4, 2008
Have you asked Ed?
DDSTANG94
465
FRASER, MICHIGAN
Dec 4, 2008
  • Dec 4, 2008
i dont want to have that much money into the intake
DDSTANG94
465
FRASER, MICHIGAN
Dec 4, 2008
  • Dec 4, 2008
nmcgrawj said:
Have you asked Ed?
no, i have asked him about a trick flow and he said not to do that...
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Dec 4, 2008
  • Dec 4, 2008
Well if he designed your cam, then wouldnt he know what is best?
Anything outside of that is a chance and a risk. You paid for Ed's knowledge, success, and experience so use it
Zero Signal
2,633
Tucson, AZ
Dec 4, 2008
  • Dec 4, 2008
Don't second guess yourself. You've already selected the path you want to take and the cam is done, just go with it. That combo is going to scream.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Dec 4, 2008
#10
  • Dec 4, 2008
  • #10
H E L L 0
I got a bit of experience with what you seek to do
I mean ... have you seen my sig
Tell us about your plans for the combo
or even better yet
Tell us what you expect after all the bugs are worked out
I'll be happy to share what I've found ... If I can
Grady
ProKiller
3,064
15
78
PA
Dec 5, 2008
#11
  • Dec 5, 2008
  • #11
this i don't understand. your willing to put money into a crappy quality intake rather than put money into a good quality intake that will get more money resale if you ever change up.
to each his own i guess
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Dec 5, 2008
#12
  • Dec 5, 2008
  • #12
I agree....i was a bit confused when he said that also.
But i guess if he were to sell the RPM....but the typhoon....then port it, he'd have "less money" into the typhoon than the RPM. But how much less....he'd only know until he sold his RPM. I dont see it being that profitable to warrant it stepping down to an intake with less quality.
Also, unless you buy a holley used.....those intakes are really expensive.
I'd talk to Ed, ask him would the cam need to be degreed any differently if you got a ported intake. Then decide if you really even want to spend the money now or wait. Personally, i'd wait until you get the combo together and running and then upgrade parts. Dont wanna put out all your funds before you even know what bugs you'll encounter.
Black95GTS
1,644
Marlborough, MA
Dec 5, 2008
#13
  • Dec 5, 2008
  • #13
1 - Ask Ed
2 - The holley intake will not fit under a stock hood, someone correct me if I'm wrong
Adam
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Dec 5, 2008
#14
  • Dec 5, 2008
  • #14
Really? I've never heard a holley cant fit on a 302 under a stock hood....
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Dec 5, 2008
#15
  • Dec 5, 2008
  • #15
It won't fit under with spacers, but it will fit if you don't have to run a spacer on it.
Kurt
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Dec 5, 2008
#16
  • Dec 5, 2008
  • #16
Why is a spacer needed? EGR or something with the valve cover?
vladasap
294
nyc, ny
Dec 5, 2008
#17
  • Dec 5, 2008
  • #17
a heat spacer
they decipitate heat btwn the upper n the lower so that upper stays cool
hence colder denser air
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Dec 5, 2008
#18
  • Dec 5, 2008
  • #18
vladasap said:
a heat spacer
I didnt think those were that popular. It definately isnt a must. I thought it would be a spacer about something you needed in order to run the intake....not to just get a little cooler air.
vladasap
294
nyc, ny
Dec 5, 2008
#19
  • Dec 5, 2008
  • #19
well to my surprise they relly do work
my intake used to get burnin hot from regular driving, but now it stays remotly cool no matter how easy or hard i get on the car
how much power that produces i dont know but i do know that it deff does keep it noticably cooler
Black95GTS
1,644
Marlborough, MA
Dec 5, 2008
#20
  • Dec 5, 2008
  • #20
Kurt
If you look at the part description on summit etc. it is not listed as fitting on a stock 94-95 mustang, only 86-93. I believe it won't fit over the stock 94-95 valve covers, so you then need a spacer to clear those, but then it won't fit under the hood.
I believe if you switch to to Fox valve covers it will fit over those and you won't need the hood. Either way I think you're going to need to do something, either new VCs or a new hood, and I know budget was an issue for you so I'm just throwing it out there that you should look into it before you consider it an option.
Ed will be able to straighten you out for sure, be sure to ask him.
Adam
1 of 2 Next Last
P0443 : what to do with this nightmare ?
  • shadad
  • Mar 4, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Feb 5, 2026
horse sence
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
HP woes with Sniper Sytem
  • Stang_1973
  • Mar 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 13, 2025
revhead347
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
V
pushrod 5.0 (MILD/ Torque) turbo build for an old scout II help
  • vz58
  • Apr 21, 2024
  • Other Auto Tech
2K
Other Auto Tech Jan 21, 2026
Flyboy60
F
