I'll defer to your knowledge since I've only recently started looking.I stand by what I said earlier. 1500 and not a penny more. That same car can be found for far less if you look around.
Thanks for the input.
Tipsy
Thanks. I'm not going to buy the car. But like I said, I plan to do a LSx swap, so I have no need to drive the car and work on it at the same time. I will yank the engine as soon as I have a garage in which to do so.You could good buy a 5.0 liter for $2500 in running driving shape that you could drive and work on at the same time. Buyin a 4 banger for 2500 just makes zero sense, you know the time and money its goin to take you to make the swap, just look for a 5.0 car, if that car was 1000-1200 it would be a different story, again, just not worth it
All of this has already been considered. I'd plan to swap the entire rear from a '94-'95 and the front brakes are also an easy swap from a SN95. I'd be converting to five lug one way or the other. It's just as easy to swap the entire rear.The problem with buying a 4-popper car is that the entire car is built weaker than the V8 cars. Wimpy rear end, smaller front brakes, softer springs, etc, etc. If you plan on swapping all of that, then it doesn't matter, but you would just be starting with a "better" car if you found a V8 car.
Misguided in your opinion. If you're truly disturbed by something as trivial as how I plan to spend some free time, you might want to consider talking with a professional.I'm not sure what disturbs me more....the thought of a good 5.0L car going under the knife to another misguided LSX swap project, or yet another clean 4-cylinder car going under the knife...
Tipsy
As far as an LSx swap wtf not? Just a cam in an LS engine 6.0 if we must be specific is good for over 90 hp at the crank which would put it to just about 500 at the crank. Oh you want more, Add a set of heads to it.
I live in NYC (10128) but I'm looking for a house on the FL Gulf coast. Once I have the house, that's where I'll be doing the work. I'll be splitting my time between NYC and FL. No place to do the work here in the city.Tipsy, if you would post up your general buying zip so that these other people who have shed great wisdom upon you can use it to find a cleaner, rust free 4cyl for you; it would be appreciated.
Whoa guy, not even a hint of hiding your cynical connotations. Shoot a bunch of guys for trying to help....I'm not sure where any of you other guys are from with your you-can-buy-cleaner-for-cheaper; doesn't do this man a lick of good unless you are within a 100 miles of his zip code.
I know one of you has a sister's best friend, next-door neighbor who's buddy happens to own the Fox Kindom and has a mint 4cyl car with no rust and clean interior for 1500 and it happens to be a coupe.
I can tell you that anywhere within 150 miles of Chicago, a deal like this will not be found, and therefore I would not advise this guy that you can find cleaner for cheaper. If he acquired a clean shell for two, he'd be doing very well in my neck of the woods. He could sell off the 4cyl, trans, all brake parts to someone who want to keep their 4-banger going.
Trailblazer SS Bolt-Ons - Headers and Cat-Back Exhaust - Super Chevy Magazine
LS2 engine tests stage one and two - cams and heads - GM High Tech Performance
"Our numbers for just the Stage I Livernois cam uncovered impressive potential in the LS2. Peak numbers rang out at 494.4 hp at 6,400 rpm and 450 lb-ft of torque at 5,200 rpm. That's a quick, 90hp pop for just a cam change! Torque numbers were up at peak, with only a slight loss down low--369.8 lb-ft at 3,000 rpm, showing that the engine will still offer good grunt with the cam. More interesting is the useable area under the curve and how much more useable rpm the engine picks up. With this cam, you won't need to shift the car until well past 6,500 versus peak numbers of 5,300 rpm for the stocker. Not only will you gain big power, but with an additional 1,000 rpm to use in each gear, the car will feel stupid fast."
