whats a good cheap radiator
Jaswir
578
Orlando, FL
i seen a copper 3 row on 50resto.com for 178 plus shipping...
and seen alot of 2 row alum. ones on ebay for around 200-250....
whats a good one for the florida heat? i need to upgrade but don't want to spend alot!
what u guys running?
I will be ordering a 4core brass unit from a company called sacramento mustangs...they are on ebay for 259 plu 8 bucks for shpping anywhere in the us.....I will let you know how that works for me and if it works for me it will work for anyone....im in phoenix
How cheap is cheap to you?
I love my Griffin, $180 from Summit... it's the 31x19" universal 2 row... fairly well documented on here. The only downside is it doesn't have a petcock so you've got to pull your lower hose to drain the coolant, but who cares, it's a top quality aluminum radiator for under $200. Eventually I might have a radiator shop braze in a petcock if I can have it done fairly cheap.
My 90 fox had a over heating / high temp issue for a while, I chased it with flush's and T stats. Finally i got a stock 2 row pass radiator with AOD cooler in it and all the worries went away. Im in tampabay area and its hot as hell here also in traffic , unless you have alot of mods and such a 2 row pass will be fine.After removeing the old 17 year old rad , i began flushing it and omg was it clogged
