What's a good torquey street cam for GT-40P's?
A set of 1.7 roller rockers will fix the lift (up from 0.444" to 0.472") and add 2-3 degrees to the 0.050" lift opening duration.
:bs:
Yikes, are you brain dead??? Lift @ .050 is measured with a dial indicator tip positioned on the valve lifter body! How does increasing the leverage at a fulcrum point (that would be the rocker arm) have ANY impact on duration (that would be degrees) of a cam timing event??? Have you ever degreed a cam????? :bs:
I like the TFS1 cam myself for your combo but it's funny how nobody recommends anderson cams from anderson motorsports. a couple of guys I know have their cams and they seem to a pretty stout cam shaft. The N-41 & N-412 where made the the GT-40 heads in mind but their B cams look pretty nice as well. thought I throw it out there.
