Codes 44 & 94 - AIR system inoperative - Air Injection. Check vacuum lines for leaks, & cracks. Disconnect the big hose from smog pump: with the engine running you should feel air output. Reconnect the smog pump hose & apply vacuum to the first vacuum controlled valve: Its purpose is to either dump the pump's output to the atmosphere or pass it to the next valve. The next vacuum controlled valve directs the air to either the cylinder heads when the engine is cold or to the catalytic converter when the engine is warm. Disconnect the big hoses from the back side of the vacuum controlled valve and start the engine. Apply vacuum to the valve and see if the airflow changes from one hose to the next.
The two electrical controlled vacuum valves mounted on the rear of the passenger side wheelwell turn the vacuum on & off under computer control. Check to see that both valves have +12 volts on the red wire. Then ground the white/red wire and the first solenoid should open and pass vacuum. Do the same thing to the light green/black wire on the second solenoid and it should open and pass vacuum.
Remember that the computer does not source power for any actuator or relay, but provides the ground necessary to complete the circuit. That means one side of the circuit will always be hot, and the other side will go to ground or below 1 volt as the computer switches on that circuit.
The computer provides the ground to complete the circuit to power the solenoid valve that turns the vacuum on or off. The computer is located under the passenger side kick panel. Remove the kick panel & the cover over the computer wiring connector pins. Check Pin 38 Solenoid valve #1 that provides vacuum to the first Thermactor control valve for a switch from 12-14 volts to 1 volt or less. Do the same with pin 32 solenoid valve #2 that provides vacuum to the second Thermactor control valve. Starting the engine with the computer jumpered to self test mode will cause all the actuators to toggle on and off. If after doing this and you see no switching of the voltage on and off, you can start testing the wiring for shorts to ground and broken wiring. An Ohm check to ground with the computer connector disconnected & the solenoid valves disconnected should show open circuit between the pin 32 and ground and again on pin 38 and ground. In like manner, there should be less than 1 ohm between pin 32 and solenoid valve #2 and pin 38 & Solenoid valve #1.
If after checking the resistance of the wiring & you are sure that there are no wiring faults, start looking at the solenoid valves. If you disconnect them, you can jumper power & ground to them to verify operation. Power & ground supplied should turn on the vacuum flow, remove either one and the vacuum should stop flowing.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
See
http://forums.stangnet.com/attachment.php?attachmentid=50636&d=1180923382 for a very nice drawing of the Thermactor Air System (smog pump) plumbing
If you have a catalytic converter H pipe, you need to fix these codes. If you don't, then don't worry about them
TAB & TAD solenoid valve eliminators – eliminate codes 81 & 82 and 44 & 94
Don’t do this if you have a catalytic converter H pipe. The catalytic converters must have the air from the smog pump or they will clog up and choke.
See
www.Newark.com for the resistors to replace the TAB & TAD solenoids
http://www.newark.com/jsp/Passives/Wirewound/OHMITE/43F82RE/displayProduct.jsp?sku=64K8974
If the link fails do a search using the park number
82 ohm, 3 watt wirewound resistor, 94 cents each.
Newark P/N 64K8974
Ohmite part # 43F82RE.
Pay a visit to your local Radio Shack to get some heat shrink and some crimp on tap terminals. They do not stock the resistors. Or you can use the Ford connector pin kit from AutoZone.
18 gauge crimp on taps Catalog #: 64-3053
Put the resistor inside the heat shrink tubing and crimp the connectors on. I would choose the Ford pin connectors since they should plug in the TAD wiring. That way you haven't modified the wiring so it is easy to re-install the TAD solenoids if emissions testing comes to your area.
This isn't a guaranteed fix, but it is cheap enough (less than $10) that you can experiment with it.
