I have the alu. DS,its alot better then the stock one(alot less vibration) but I still get drivetrain vibration under hard excelleration.What would be the next step up? I see ads for chromemolly DS's,but are they better?
When I put gears in,the vibration was really bad at high speeds.The alu. ds helped out alot.But there is still vibration.I'LL check that stuff,but the car has low miles on it.Maybe the mount is dry rotted,but I doupt it.raph130 said:you shouldn't be having vibration even with a stock driveshaft *if its rotated correctly* and aftermarket gears. i would check your transmission mount, and the d/s bolts and check if the pinion nut is loose or not. unbalanced tires can cause vibration also. there are 4 driveshaft positions.
The stock one does s@ckcevtv said:Check your harmonic balancer.........the stock ones suck!
check the phone book. often the shops do driveline repairs (after frame work) or work on big rigs (those DS's take a beating). some people have had a hard time finding one. if you cant find one, call some places and ask if they know of a shop that can do dynamic driveline balancing.willys1 said:Hissin50,thats a great idea,but what exactly is a driveline shop??
In respect to gear install, if it vibrates under hard acceleration then it could very well be that something isn't tightened down, the pinion preload isn't correct or even the pinion nut isn't tight enough. I would have to point fingers at the gear installation.HISSIN50 said:also, Adam had a good point about possible issues inside the pumpkin.
ok,theres actually a few big rig shops in my area.HISSIN50 said:check the phone book. often the shops do driveline repairs (after frame work) or work on big rigs (those DS's take a beating). some people have had a hard time finding one. if you cant find one, call some places and ask if they know of a shop that can do dynamic driveline balancing.
The whole unit,or just the u-joints?BlackFox5.0 said:Try rotating the DS 180* on the rear end. That solved it for me, twice.
willys1 said:The whole unit,or just the u-joints?
