whats considered mostly stock...
  • Thread starter Thread starter 90mustangfan
  • Start date Start date Nov 17, 2005
90mustangfan
93
So cal
Nov 17, 2005
  • Nov 17, 2005
Here are my mods for my 89' LX 5.0 It has starting from intake back: Pulleys, Bypassed smog and A/C, Electric fan,180 t-stat,C&L 76mm MAF, BBK CAI, BBK headers, BBk O/R H-pipe, Flowmasters, 3.55 gears, Rebuilt all forged 306, crane cams(emissions legal), rebuilt top end: New valve springs, 1.6 RR's, pushrods, valves, etc...pro 5.0 shifter...is this considered lightly modded? Im going to add a 70 mm tb, I dont think its to big, in fact I put a 70mm tb on another stang same mods, it made 2nd and 3rd gear pull so much harder, and added quick throttle responce,before Tb I could spin second that much, after the TB, I could spin all of sencond and chirp 3rd, why do people think you dont need a 70mm TB? I got great gains from it...
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Nov 17, 2005
  • Nov 17, 2005
Stock means that the car still has all of the equipment from the factory (and that it's still functional)
Slightly modded means mostly bolt on goodies and some gears.
That is how I understand it.
RsStanG1987
I shaved all my pubes playing this game.
569
9
79
Dupont PA
Nov 17, 2005
  • Nov 17, 2005
Yeah your not stock if you got a 306
ALMOST STOCK
1,250
41
88
CA.
Nov 17, 2005
  • Nov 17, 2005
So..... that's ALMOST STOCK then.
87gtconv
ragtopman
2,595
Southern Calif
Nov 17, 2005
  • Nov 17, 2005
You loose lightly modified when you add a power adder or more cubes
KDK1988GT
1,937
Fredericton
Nov 18, 2005
  • Nov 18, 2005
I think
if you only run exhaust, pullies, cold air, gears,, I say that is pritty much mostly stock...
Once u get into changing heads, cams, rockers, intakes, and going with extra cubes... then you are modded...
Are we only talking about motor parts? What if you change suspension and other things??
srothfuss
Oct 17, 2004
1,796
Woodward Ave.
Nov 18, 2005
  • Nov 18, 2005
So so far we have:
Stock:
Using all OEM parts. No upgrades except mufflers. Still must have stock brakes, driveline, suspension and rim's
Almost Stock:
Using only bolt-on parts. Stockish rebuilds with engine displacment ranging from 302CID to 306CID. Maybe upgraded suspension components (still using stock K-member), HD clutch for the T-5 or shift kit for an AOD. Stock headers, O/R H-pipe and exhaust. Still stock gears, brakes and rims.
Slightly Modified:
H/C/I swaps + stockish rebuilds with engine displacment ranging from 302CID to 311CID. Upgraded suspension components (still using stock K-member), super HD clutch for the T-5 or shift kit and converter for an AOD. Aftermarket headers, O/R H-pipe and exhaust. Steeper gears, minimal brake upgrades and new (larger) rims / tires.
Modified:
H/C/I swaps + rebuilds with engine displacment ranging from 327CID to 347CID. Some sort of power adder - block spittling horsepower. Upgraded suspension components (tubular K-member), HD Transmission [TKO, T-56, etc.] or Beefed up AOD. Aftermarket headers, O/R H-pipe and exhaust. Steeper gears, "cobra" style brake upgrades and D/R's for help with traction.
Heavily Modified:
H/C/I swaps + rebuilds or swaps with engine displacment ranging from 327CID to 460CID. Some sort of BIG power adder. Required Dart block because you split your original block in half while you were in the moddified catagory. Upgraded suspension components (tubular K-member), HD Transmission [TKO, T-56, etc.] or Beefed up AOD. Aftermarket headers, O/R H-pipe and exhaust. Steeper gears, "cobra" style brake upgrades and seperate racing tires for help with the lack of any traction.
I don't know what catagory I fall in. I can say that with each bracket that you move into and on to the next there is an ever increasing amount of money spent.
04sleeper
2,674
14
89
Dallas, TX
Nov 18, 2005
  • Nov 18, 2005
This sounds not stock to me.
Do you still have a stock intake?
H
Engine new engine troubles
  • hawkinsdrag
  • Nov 6, 2022
2K
Fox 5.0 Mustang Tech Nov 10, 2022
Monkeybutt2000
M
For Sale 3-owner 1987 Mustang GT, $18K obro, Lancaster CA
  • Bill Cool
  • Oct 6, 2024
2K
Fox Body Mustangs For Sale (1979-93) Oct 13, 2024
nickyb
A
1991 5.0 with HCI - started car, running for a few minutes, started pushing coolant into the overflow tank and then puking out from there. I'm lost
  • AmericanMuscle4.6GT
  • Oct 16, 2022
4K
Fox 5.0 Mustang Tech Nov 30, 2022
CAMTWO1070
LESS THAN 9.5 MPG CITY DRIVING!!!
  • PonyGTrider
  • Dec 15, 2022
  • 3 4 5
12K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 6, 2023
PonyGTrider
Engine A few issues with my new 88 Foxbody that i couldnt find definitive answers to....
  • AydenTv
  • Mar 6, 2022
3K
Fox 5.0 Mustang Tech May 23, 2022
7991LXnSHO
