* 331 cid *
Bore Size: 4.030
Gasket Bore: 4.100
Piston Top Land Dia: 4.000
Stroke: 3.250
Connecting Rod Length 5.400
Compression Height: 1.175
Deck Height: 8.200
Ring to Top of Piston 0.250
Gasket Thickness: 0.040
Valve Notches Volume: 4.00
Dome Volume: 0.00
Volume Head: 58.00
:COMPRESSION RATIO: 10.511
calculation variables:
Piston to Deck: 0.000
Crank Throw: 1.625
Vol. Above Top Ring: 0.78 cc
Piston to Dec Vol.: 0.00 cc
Gasket Volume: 8.65 cc
Volume Clearance: 71.43 cc
Cylinder Volume: 679.33 cc
CID: 331.515
(notes/messages)
× Piston Flush with Deck
Friday, September 23, 2005 9:02 am
* 331 cid *
Bore Size: 4.030
Gasket Bore: 4.100
Stroke: 3.250
Deck Height: 8.200
Dome Volume: 0.00
Volume Head: 61.00
:COMPRESSION RATIO: 10.127
Crank Throw: 1.625
Volume Clearance: 74.43 cc
CID: 331.515
