Whats needed?
what are my absolute needs to convert from efi to carb. other than the carb. and lower intake? can i use my in tank fuel pump or no. any help will be greatly appreciated. thank you!!! also what cfm carb. do you recommend for good hp and daily driven . its a 302 with gt40 alum. heads and long tubes.
87_stang
131
Tonganoxie, KS
You will need the carb, intake, ignition system (Summit sells a good HEI setup for you), different fuel pump. I'm sure there are more but can't think of them right off hand. I would saya 600-650 cfm carb would be plenty for what you have right now. Better to be just right or a little small than to over carb it. Good luck.
