Whats next??
  • Thread starter Thread starter projectfiveo
  • Start date Start date Aug 26, 2006
P
projectfiveo
347
Aug 26, 2006
  • Aug 26, 2006
What is the best bang for my buck horsepower wise after 3:73's and 76mm MAF?? Well besides heads.... I was thinking about getting the Trick Flow Steet Heat Intake...but Id say it would cost a fortune to have it installed
Heres what i got done so far: 3:73, bbk cold air, 76mm MAF with inlet pipe, underdrive pulleys, 155lph fuel pump, headers, x-pipe, flowmasters, msd ignition, smog pump removed, front sway bar removed, alum. driveshaft, and king cobra clutch...... and getting tokico struts/shocks, eibach pro springs, and rear end rebuilt next week......anyone have any idea how much hp i might be pushing?
thanks in advance guys!
M
MattTheBat83
203
  • Aug 26, 2006
go for the intake and just install it yourself
P
projectfiveo
347
Aug 26, 2006
  • Aug 26, 2006
how hard are they to install??
gcwh02
515
pottstown, PA
Aug 26, 2006
  • Aug 26, 2006
piece of cake, i'd go the street heat if I were you also. Then if you ever need a bigger intake for your combo just buy the track heat upper and it bolts right on to your street heat lower because they use the same one.
P
projectfiveo
347
Aug 26, 2006
  • Aug 26, 2006
is there any step by step instructions floating around anywhere out there for the install? and should i replace anything else while im changing it?
J
jmd2914
937
Napa, California
Aug 26, 2006
  • Aug 26, 2006
what tb are you running?
P
projectfiveo
347
Aug 26, 2006
  • Aug 26, 2006
i have a stock TB right now but i want a 70mm
P
projectfiveo
347
Aug 27, 2006
  • Aug 27, 2006
anyone else?
Dayzed50
106
Marysville, WA
Aug 27, 2006
  • Aug 27, 2006
step up to a 65mm or 70mm tb and get a short throw shifter. also, consider some cobra 1.7 roller rockers and a plenum spacer for cooler intake temps.
J
jmd2914
937
Napa, California
Aug 27, 2006
#10
  • Aug 27, 2006
  • #10
like dayzed said id get a bigger tb and possibly a short throw before you worry about a new intake mani.
LXSTASY
932
Long Island, NY
Sep 7, 2006
#11
  • Sep 7, 2006
  • #11
I'd get a short shifter, intake and throttle body. They are all easy mods and can add to the mass air meter swap that you already did.
myslo50
247
ohio
Sep 7, 2006
#12
  • Sep 7, 2006
  • #12
i would go over to the local salvage yard and get an 5.0 explorer upper and lower intake. i got mine for $150 and installed it my self. best bang for your buck. that way u have more money to spend on others for the price of a tfs intake
I
Engine What Aluminum Heads???
  • Iceman1998
  • Sep 8, 2024
2K
Fox 5.0 Mustang Tech Sep 15, 2024
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
Progress Thread "Alter Ego" White 1993 LX 5.0 5spd
  • idareu
  • Sep 9, 2024
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 19, 2025
idareu
For Sale 3-owner 1987 Mustang GT, $18K obro, Lancaster CA
  • Bill Cool
  • Oct 6, 2024
2K
Fox Body Mustangs For Sale (1979-93) Oct 13, 2024
nickyb
