Whats next??
projectfiveo
347
What is the best bang for my buck horsepower wise after 3:73's and 76mm MAF?? Well besides heads.... I was thinking about getting the Trick Flow Steet Heat Intake...but Id say it would cost a fortune to have it installed
Heres what i got done so far: 3:73, bbk cold air, 76mm MAF with inlet pipe, underdrive pulleys, 155lph fuel pump, headers, x-pipe, flowmasters, msd ignition, smog pump removed, front sway bar removed, alum. driveshaft, and king cobra clutch...... and getting tokico struts/shocks, eibach pro springs, and rear end rebuilt next week......anyone have any idea how much hp i might be pushing?
thanks in advance guys!
piece of cake, i'd go the street heat if I were you also. Then if you ever need a bigger intake for your combo just buy the track heat upper and it bolts right on to your street heat lower because they use the same one.
is there any step by step instructions floating around anywhere out there for the install? and should i replace anything else while im changing it?
i would go over to the local salvage yard and get an 5.0 explorer upper and lower intake. i got mine for $150 and installed it my self. best bang for your buck. that way u have more money to spend on others for the price of a tfs intake
