What's the best supercharger setup for 2006 GT?
what are you looking for? street use and low end power? if so, so with a twin screw/roots type supercharger such as saleen, whipple, K.B., etc. there will be more usable power for the street.
if you are going to start racing and want upper RPM power, then go with a centri style, like procharger, paxton, vortech etc.
06 Procharged Mustang GT Dyno Results!
We just finished up our 06 Mustang GT Project this morning. Here's a rundown of the setup.
Kooks 1 5/8 Longtube Headers with Catted X-Pipe
Borla Cat-Back Exhaust
SPEC Stage 3 Clutch
3:73 Rear-Gear
P-1SC Procharger @ 9.5 PSI
Below is the dyno
http://ls1tech.com/forums/showthread.php?t=522402&highlight=procharger+mustang
This tune is super conservative. We can easily reach 500RWHP without increasing the boost but we don't want to push this stock short-block too far. Eventually the customer wants to do a low-compression stroker motor, upgrade to the D-1SC blower and turn the boost up!
SPEC Stage 3 Clutch
3:73 Rear-Gear
Are those the only mods? How're the stock injectors doing and how well is the engine holding up? I'm looking to run the Saleen at 7-9 PSI but have no idea where to start.
PS: And also looking to keep her running good for a while..meaning no break downs, no blown engine etc etc
Start by calling Jim jr at JDM engineering.They have stage 2 kits running 8psi 450rwhp.100's of kits sold 0 engine failures.
I've been running the kit for months in 110 degree heat no problems.:nice:
Nah those are the injectors procharger sent us but I cant remeber how big they were............ most people forget when adding power that their fuel system really cant keep up so I would look into imporving your fuel system as well
This is a loaded question.
Pick a company that has the best support, cheap price should not be your main plan.
Also remember the blower is totally worthless with a bad tune.
I am leaning toward Ford/Whipple for one reason only, Ford does the tune and not billy bob down the road.......
So hate to say it, the decision is all on you............
SPEC Stage 3 Clutch
3:73 Rear-Gear
Below is the dyno
This tune is super conservative. We can easily reach 500RWHP without increasing the boost but we don't want to push this stock short-block too far. Eventually the customer wants to do a low-compression stroker motor, upgrade to the D-1SC blower and turn the boost up![/QUOTE
Now that is a fat a/f.
