  • 1994 - 1995 Specific Tech
Whats the differance ---> distributor stator vs ignition module?
  • Thread starter Thread starter 1TRIKGT
  • Start date Start date Apr 27, 2005
1TRIKGT
191
Miami, Fl
Apr 27, 2005
  • Apr 27, 2005
I read a thread about a week ago from a guy that had a similar problem as I am with my 95 and changed what he called a distributor stator which fixed the problem, so I told my mechanic whos working on my problem and he said thats what hes changing next but that its not under the distributor like the guy said his was and that its called an ignition module which is located inside the passenger side fender. Are these the same thing?
94-302-vert
1,947
NE CT
Apr 27, 2005
  • Apr 27, 2005
These are not the same thing. I haven't had any expereinece with either one but I do know they are not the same.
Most seem to refer to a SPOUT (spark output) or PIP in the distributor as the culprit.
Chris
M
_MATiC
140
El Paso, TX
Apr 27, 2005
  • Apr 27, 2005
yeah..the stator is INSIDE your distributor. it's also knows as the PIP, hall effects sensor, blah blah. if you're having your car randomly die or shut off after a litle bit of driving, then u should replace that. the piece itself costed me like 10-15 bucks @ autozone.
1TRIKGT
191
Miami, Fl
Apr 27, 2005
  • Apr 27, 2005
yea at first it wouldnt start every once in a while then it started happening more often and progressed into shuting down on me as soon as i start it or while i was driving. Its like the rpms just drop dead.
rude_life
372
  • Apr 27, 2005
All i can say is GOOD LUCK getting that thing out of there. I cracked my distributor on my last mustang which was a 94' GT as i was attempting to remove the piece on the bottom to get to it.
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
R
1994 GT 5.0L crank no start
  • Red1994MustangGT
  • Apr 15, 2025
2K
1994 - 1995 Specific Tech Aug 19, 2025
Kurt_MO
K
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
9
96 mustang gt
  • 96projectgt
  • May 2, 2025
  • 2 3
2K
1996 - 2004 SN95 Mustang -General/Talk- May 15, 2025
96projectgt
9
