Whats the fastest way to drill out a broke of bolt?
are you going to drill the bolt all the way out or are you gonna drill a hole and than use an 'easy out'. thats what i would do. just talk to someone at the hardware store and ask them what drill bit would be good to drill metal...?
Im guessing u broke the heads off? If so, remove the water pump and use some vise grips on those broken bolts. The other way is to use and EZ out tool. Basically a drill bit with reverse threads.
Bingo.....
Some of those bolts go into the block, so you really don't want to have to try to drill them out, they also go through the timing cover.
If you really must drill them, then a carbide bit.. If you haven't drilled them too deeply, take a large nut and hold it on top of the bolt, and tack weld the inside of the nut to the middle of the bolt, then you can wrench it out.
Yea i would agree with what everyone else has said, but EZ outs seem to work the best for me if you can get to them. use some good rust penetrating oil too and let it sink in before trying to remove anything, this should help out a lot....good luck man
I broke a bolt yesterday that goes to the water pump. Lucky for me it's one that's up top and doesn't go into the block or timing chain cover. Should I still use an ez out or just drill the hell out of it?
An EZ out would be the preferred method...Is the bolt sticking out the back of the timing-chain cover? If so, you can cut the bolt between the cover and water pump, an continue to thread the bolt though until it removes itself.
How to use an EZ out:
You'll need - a set of EZ outs, Vice grips, hammer, drill, drill bits, SAFETY GOGGLES.
Drill a hole into the middle of the bolt, leaving enough room on the outside of the shank so it wont break, crack, or split. If its a 1/2in thick bolt, youll want to use a 1/4 in drill bit...make sense? Once th hole is drilled, no deeper then 3/4 inch shouod be needed.Secure the EZ out into the vice grips flush with the teeth of the vice grips, not stright foward, just like a set of plyers. The EZ should go into the hole deep enough, but not bottoming out. Then, using the hammer, tap the EZ into the hole unitl it goes no more, now continue to tap/hit the ez out/ vicegrips while turnin tghe ez out/ vice grips in a counterclockwise rotation. The bolt should break loose and spin out. If the EZ out isnt gripping, hit it harder, and rotate slowly. DONT break the EZ out in the hole! Its ok to drill deeper if needed, but try not to widen the hole too much.
Legendary said:
Well I didn't want to take the water pump off. I was adding an March alternator bracket and it required that I removed the bolt. You can still see it poking through the back.
How much is poking through the back? Grab that little end with some vice grips and unsrew it.It should unsrew enough to grab it on the waper pump side and continue to unsrew it. good luck, be creative, youll figure something out.
In case u didnt know....vice grips are a very essential tool.
Water pump broken bolt fixit kit:
http://www.mscdirect.com/PDF.process?pdf=1088 Use drill bushing 5/16” OD, 5/32” ID, ¾” long, price $8.57 This centers the drill bit in the housing bolt hole so you don’t get off center and damage the water pump, timing cover housing or engine block
http://www.mscdirect.com/PDF.process?pdf=18&Keyword=Y drill bits - use 5/32” Cobalt/TiN coated bit #78530433, price $3.91
http://www.mscdirect.com/PDF.process?pdf=1951&Keyword=Y Screw/bolt extractors. Use EZY-OUT Screw Extractor #63760037 Price $2.67
One step specialty item: See Drill-Out® Broken Bolt Extractors drill bushing, reverse twist drill & extractor all in one unit. Best to use when the bolt breaks off with the remaining part below the start of the threads. Price $18.33 each. You MUST have a reversing drill motor (either air or electric) to use this bit.
A long shank tap should be used to chase the leftover metal out of the original threads. Also recommended to clean the corrosion and dirt out of the threads before you reassemble everything. Cleaning the threads will help prevent the bolts from seizing next time (yes, there will be a next time).
Long shank 5/16” taps
http://www.mscdirect.com/PDF.process?pdf=287&Keyword=Y 5/16” pulley tap, 6” shank #04801189 price $14.26
OR second choice, will not clean all the bottom threads unless you grind the end of the tap.
http://www.mscdirect.com/PDF.process?pdf=286&Keyword=Y extension tap, 6” reduced diameter shank #04701181 $16.17
See http://www.windsorfox.com/detail.cfm?id=ENG-TBK for Stainless Steel Water Pump Bolts with Custom stainless steel studs. Allow the use of factory accessory brackets without hunting for obsolete parts or using spacers.
Kit comes complete with nine polished stainless 12 point bolts, four stainless studs and nine stainless oversized washers.
Price: $58.95
I had 3 bolts break off inside the block when I was removing the waterpump/timing cover doing my engine rebuild. So I had to have the machine shop get them out while boring the cylinders...sucked. We thought we had to find a new block cause they almost couldn't get one out
