What's the material inside the Window Track?
Tim65GT
1,149
West Texas
This web site says its burlap?!?!
http://www.mustangmonthly.com/howto/173_0306_wind/
Can it be purchases somewhere?
Is it hard to replace?
Apparently it was only 65-66 models that have it.
Thanks for the reply.
Thats the first thing I did was look through the popular vendors' pages of
"door" and "window" searches, 'cause I don't know what ya call it.
I was thinking of just take the track with me to a fabric place here in town that stocks a crap load of auto type stuff and see if they have any.
Any one ever replaced this material or heard of it?
I had a heck of a time finding it. Tried all the Mustang parts vendors, paint/body supply shops, glass shops, etc. I finally found it at a vintage FOrd truck supply shop. It is called "Bulk glass tape"
EDIT - Nevermind. I was thinking it was something else (pic didn't load the first time). Isn't the stuff in the pic called moleskin? I got mine from NPD
I never found it for my '66. I just went to my upholsterer and had him pick some "stuff" that would work. It is a bit softer than the original but he says he has used it before and has worked good. It looks like a soft but heavy burlap but it is not burlap. He installed it and it is doing dreat.
Thanks for the replies.
We have a place called Texas Fabric and Foam. I'm sure they can hook me up.
I just like to get all the stuff together BEFORE I go tearing into a project.
Sometimes ya have to wait 'til you have part in hand to get what ya need.
I bought the material today for the window track. They didn't have the exact type stuff, so I got 2" wide velcro... just the loop part, not the hook part. I scraped all the old crap out, what was left of it that is...
Then glued in the velcro. I'll post pics later when I get it together and see how it works.
I also took a lot of good pics of the latch, rods, and my new fabricated electric lock motor modification.:nice:
i thought moleskin was what they used on the window channels to keep the glass from rattle around when the window is up/down and to keep water/crap out of the inside of the door.
The product "Mastic" was used in window channels since the 1920's - 1960's. You can usually find it at a good Automotive Glass company (Safelite). It comes in different thickness and you want it tight that you can not push the track onto the glass but that you need a rubber/plastic mallet to install.
I was talking about the window track not the stainless piece that wraps around the window.
Anyway I got a couple pics of the latch fix and rod configuration.
Here is the lock motor I modified to fit from a 82 Thunderbird. I used an existing hole in the lock lever.
I started to put the door and hinges back on, but it looks like the only way to get it aligned right is to take the fender off.:bang:
Yeah, I've got a old Sony DSC-S50 with the flip-out viewer that you only see on camcorders anymore. I also had my twin 13w flourescent drop light in the door. I figured I was only gonna get a pic like that once, so it should be a good one.:nice:
I'm sure the latch assembly is different, but the operation is the same, I would think.:shrug:
Very nice pictures indeed. I have a question for ya though, how are the rods attached where I have circled them in your picture.
As of now i have to crawl through my passenger side door to get in my car :notnice: because the rod that goes from the outside pushbutton to the red circle in the picture falls out of its place when I shut the door. I cant seem to figure out how it stays in there.
here is one source:
http://www.mustangsunlimited.com/itemdy00.asp?T1=F1306+01
If you look at the last pic I just posted, it shows the tip of the bushing has a cut out just for the rod.
Yours proly got old.
Mine was missing and a PO bent the rod in a U through both.
It allowed the door to be opened even when locked.:eek:
Glad I could help. When I asked the vendor though email, they sugested I buy a manual.
The manual show NOWHERE near the detail the picture I took.
haha that would suck. mine is completly gone and i bought one kit but nothing seemed to work.
I just looked at the site and it only has one washer with it, do i need the other two plastic ones like you have?
