jrichker said:I recommend that to make you Mustang run at peak efficency, you do some reading...
Here's a book that will get you started with how the Ford electronic engine control or "computer" works.
Ford Fuel Injection & Electronic Engine Control 1988-1993 by Charles Probst :ISBN 0-8376-0301-3.
It's about $20 from Borders.com see http://www.amazon.com/ . Select boo...ther than that, best dollars spent on the GT.
come again? i know it depends upon what one's definition of emissions equipment is, but the do trim the a/f ratio, which helps to lower tailpipe emissions. not sure what you meant. i think we just have different view points on what your above quote means.Ray@VSK said:O2 sensors have nothing to do with emissions
HISSIN50 said:come again? i know it depends upon what one's definition of emissions equipment is, but the do trim the a/f ratio, which helps to lower tailpipe emissions. not sure what you meant. i think we just have different view points on what your above quote means.![]()
they are part of the emissions/management equipment. i can pass emissions w/o a smog pump too, but it is part of the emissions systems and it does help. if one does not care about the life of cats, i suppose running w/o lambdas would work.Ray@VSK said:If you take a stock motor & pull the o2's ya it will richen you up a bit thus maybe making you fail emissions but fact of the matter is o2 sensors are not needed for emmisions.
It's about $20 from Borders.com see http://www.amazon.com/ . Select boo...the california cars, but why isn't it 87-93 ?
