What's your car weigh?
SPRCHRGD
37
Weighed the car today at the dump. Came in at 3138lbs without driver. Seems not to bad for SN95 with some weight loss items. What's your car weigh?
Things Ive done
Tubular k member, a arms, 2001 brakes (GT)
2003 cobra struts (3lb lighter per stock strut)
front/rear coilovers
AL heads,
AC delete
cruise delete
rear end vibration dampener? delete
fog light delete (good for cold air intake)
al drive shaft
no spare/jack
battery in back (weight dist)
air pump
Added weight
frame connectors
supercharger
those heavy A$$ 17x9 cobra r's
weighed in 3150 the other day.....
weight reduction = !sway bar, !dog bone, !spare Jack, rear seat cushions only
I do have MTX 12 inch subs, 2 amps and a crossover
3500lbs without me
Alum heads
alum pulleys
alum DS
removed smog pump
removed thermactor and EGR
offroad X pipe
removed 25lb convertible weight
removed 10lb dog bone
no spare/jack/trunck carpet
no pass seat
no rear seat bottom
Added weight:
TKO trans
Global West full length subframe connectors
GW LCA's
Chrome hooker 4 point roll bar
chrome strut tower brace
chrome wheels
Xenon ground effects
If it still has the stock heads and no weight removal... that seems right. My car weighed 3803lbs with me in it at englishtown with the stock heads, spare, jack, 10lb dog bone, etc.
Wow i figured it would have been alot lighter with the tubular k..
Makes me wonder if the scale at my track was off the day i got it weighed. I weighed in at 3250 with me in it, i weigh about 175ish
Weight loss is..
Al heads,
Al d/s,
no smog junk,
no ac junk,
dogbone,
no front sway bar,
no back seat,
gutted trunk,
no strut tower brace,
offroad x pipe,
alum pulleys,
no egr
* i think thats it, if i remember more ill add it
added weight..
17x9 chrome cobra R's
a couple gauges
msd6al
Weight loss is..
Al heads,
Al d/s,
no smog junk,
no ac junk,
dogbone,
no front sway bar,
no back seat,
gutted trunk,
offroad x pipe,
alum pulleys,
no egr
added weight..
a couple gauges
msd6al
Wow you're doing good at 3075 but I'd get a second opinion. Seems a little light. The front suspension stuff and kmembers worth about a 100 loss but then theres the S/C so maybe not :banana: :banana: :banana: :banana:
Methinks you need to find a different scale... one that's accurate maybe. That's way too light, especially with the stereo gear.
Weight loss is..
Al heads,
Al d/s,
no smog junk,
no ac junk,
dogbone,
no front sway bar,
no back seat,
gutted trunk,
offroad x pipe,
alum pulleys,
no egr
added weight..
a couple gauges
msd6al
I think your weight is pretty accurate. Aluminum heads save a ton of weight and the stock cat-pipe weighs a ton as well. The A/C is also good for several pounds. If anything, I'd think you may be a bit closer to the 3K mark.
FWIW, my GTS weighed 3260# completely stock (nothing removed) plus a Bassani SS catback. This was w/o me and 2.5 gallons of fuel in the tank. I've since added (or removed):
Fluidyne aluminum radiator - pound or two heavier than stock
16" wheels swapped for 17's - added 8# total to the car
Aluminum pullies
Tubular K-member
Tubular A-arms
Coilovers at all four corners
Cobra R Bilstein struts and shocks (maybe a 2-3 pounds lighter)
Sway bars removed (front and rear)
Smog pump and associated tubing removed
Bassani SS offroad X-pipe
Dog-bone removed
Stock LCA's swapped for MM RR LCA's (2.5# each)
Quad shocks removed
Trunk gutted, jack and spare removed
Sound deadening material in trunk removed
Rear seat deleted (without any paneling added)
Rear seatbelts removed
I've got a ton of other stuff but they're really not that much different than the stock weight (e.g. my poly motor mounts don't weigh any more or less than the stock ones).
I haven't weighed it recently but I suspect that I'm hovering around the 3100# mark. After the hood swap and Al heads, I fully expect to be quite close to 3K even. Brakes will probably be before that though and drop me a few more pounds (aluminum calipers and 2-piece rotors). There's a ton of other things I have planned as well that both add and subtract weight. By the time it's all over (is it ever?) I'm hoping for a 2900# SN-95 with me in it, a full tank of gas, and retaining A/C , P/S, and the radio.
Ya Baglock I'd guess you're just under 3100#. You mentioned some other items that we all forget about being toast like the stock Hpipe, quad shocks etc and the items I forget to add like the lower control arms (south side), My upper contols are probably lighter - UPR's.
A gts is lighter because of no wing, manual windows - what else?
Don't underestimate that stock H-pipe; it weighs a friggin ton. As far as the rest of the stuff, it all adds up. 4-5 pounds here, 3-4 pounds there... Before you know it, all that little stuff adds up to 50+ pounds.
First off, a GTS could have been ordered with any option a V6 could get. Therefore, not all GTS's are stripped down. But mine is about the most stripped you can get without getting into special deletes (e.g. the A/C required a special delete).
A normal GTS (like mine) doesn't have:
Foglights
Power leather seats (mine are the manual cloth V6 seats)
Mach 460 (I just had a tape deck)
Power windows
Power locks
Rear defrost
Cruise
Rear spoiler
I think I'm forgetting something... oh well. Additionally, my GTS (not a GTS exclusive) has the ABS deleted which is probably another 5-10 pounds lost in equipment and extra fluid.
It's the rusty thing at the top of the pic. Most people take it off when the get a steeper gear, because it's useless then.
Jake
