Wheel Bearing???? Help ASAP!
Adam95GT
2,564
Burlington, NJ
more problems with the stang...
Well today when i went to pull out of my drive was i heard a sound like i had a flat tire or something stuck in it... i pulled over and nothing was in there... it happens both in gear and out of gear... and its comming from the front pass side... just statred about an hour ago... its 2 dark out to really see anything... so it will have to wait till tomorrow... but it sounds like a light Click/pop noise like a CV joint on a FWD car... my g/f could feel it on her feet by the floor on the pass side... i kinda figured it was a wheel bearing so to get ready for tomorrow i went to autozone... and aparently they told me that we have to buy a whole hub and replace that....??? oh well does this sound like a problem with the wheel bearing// hub.... if so this is gotta be fixxed tomorrow... i start work tuesday... also if so does anyone know where there is a write up?? i looked in my fox haynes... but that shows you can just replace the wheel bearing... so i dont know... please give me some help...
http://www.partsamerica.com/ProductDetail.aspx?mfrcode=BCA&mfrpartnumber=513115&parttype=184&ptset=A
alright doesent happen in reverse only forward... now its making a creeking rubbery sound..... then the pop noise.... increases with speed.... i had it up and shook the hell out of my tire... and there was no play at all or any noise when i spun the tire... i cant figure out what this is and noone i know is around today....
Well... I went to take a look at the wheel bearing... and one of my lugs basically fell off.... i took alook and turns out it was broken off.... i dont know y it would make this crazy ass noise... anyone know how to replace a lug on the hub... or do you have to replace the whole thing...
Lugs are simple. Just take the caliper and rotor off, tap it out with a hammer, and tap the new one back in.
You might find a problem finding the right size though, when some of mine broke, it took them about an hour to find the right size. they had to actually get someone to drliver them from a local parts store.
And if you dont feel like doing it, most tire shops charge like $10-15 to do one.
Good Luck
autozone had mine in stock... lol $1.29 and a new lug for $1.99 .... yea im gonna do it tomorrow... ive read you can do it without removing the caliper and stuff... not sure how but aparently you can spin it around and then there is a spot you can knock it out....
