Wheel spacing question
golf4283
1,253
Orland Park, Illinois
Ok so I just want to know from you guys what length of spacer I need for my 1966 mustang.
I currently have a front Granada swap and a lincoln versailles rear-end
The wheels I am using are stock 2005-7 GT wheels with the stock offset etc.
I'm buying this deal here. http://www.newtakeoff.com/index.asp?PageAction=VIEWPROD&ProdID=8059
I just have no clue what sized wheel spacers I need to run with this setup.
01-04 Bullitts have a 5.72" backspacing so they require a 1" spacer/adapter all around to achieve the recommended 4.75". That's what I currently have on my coupe. I did have to use a 1.25" spacer on the rear but I have a Maverick 8" housing which is narrower. The 05 and later Stang 17" wheels have a 6.3125" backspace which would require an 1.25" to 1.5" spacer depending on how close the inner rim falls to the upper control arm up front. I have a set of 05 GT wheels that I was going to use with new spacers but no one makes an 1.75" spacer I need for the rear. The wheels I have are the ones in the attched pic, not my car though.
Ok so I have gone with 2001 Bullitt rims and I bought a wheel adapter kit with 1" spacing in the front and 1/2" spacing in the rear. I was wondering what tires I can fit in the front and rear.
Setup is as follows
Front: Shelby drop
Rear: Lincoln Versailles 9" with 5 leaf mid-eye springs.
I was hoping to not have to roll the fenders and I honestly don't even know whats involved in that. I was also hoping to fit a 235 in the front and a 245 or greater in the rear but it seems I might be limited to 245 without rolling the fender.
Any suggestions and also maybe explaining how to roll the lip.
Thanks.
