jeffnoel said:
The Granada rotors only stick out 1/4" further on each side. You can still do it without spacers by putting travel limiters on the steering rack or changing to a tubular upper control arm.
The steering is pretty damn limited at the moment, using the stock-type 5 lug rotors. I'm searching for tubular uppers now. There are tons on the net, but the best deal I've found so far is from Spartan.
http://www.westcentralauto.com/SRW.htm
"These custom 1" diameter control arms are made from 7/32 wall DOM steel. They come already Powder Coated in Hi Gloss Black, or you can get them uncoated if you prefer. They are also available in a 5/8" narrower per side design for those applications where tire clearance is at a minimum! Ball joints and mounting hardware included. Featuring an extremely sturdy lower arm mounting arrangement which eliminates the strut rod. The lower arm mounts on the outside of the cross member as shown in the demo. "
$219 a pair complete, ready to bolt on, doesnt seem bad at all.
I'm wondering how much more room the tubular arms will give my car, especially with the extra 5/8" per side they mention.
I think I need about a 3/8" spacer on the rear, too, because when I jack up the rear housing side to side, the inside of the tire brushes the framerail. I'll have to test with some washers behind the wheel to figure out how thick the spacers will need to be. I want them in as far as possible to avoid interference with the fender lip.
Car looks pretty cool with 17s on it, though, and hopefully it'll handle like a beast when I finish ironing out the bugs.
