wheels and slicks
ProKiller
3,064
15
78
PA
Okay here's the plan: I need to buy slicks.
its a short plan....
anyway, i think i'm pretty much set on Mickey Thompson M/T. but i have no clue as far as size, backspacing all that stuff. I never really cared about wheels and the spacing and sizing. if it looked good, the job was done. Its time for me to learn i guess.
what is the cheapest but best wheels and slicks that i can get?
Cheapest wheels would be used ones. Either stock V6 or stock 16X7 wheels work good, or a used set of drag wheels like welds and such. Just be forwarned that most of the weld wheels require longer wheels studs to work on our cars which adds to the expense.
As far as back spacing, a good rule of thumb is that you don't want the total of the wheel width minus the back spacing to exceed 4" MAX. I personally wouldn't let it exceed 3.75" Also, you can not fit anything much wider than 6.9" of back spacing under the car.
For example, my 10.5" wheels have a 6.75" BS which give me 3.75" from the wheel hub face to the furthest out portion of the wheel. Most of the 10.5" cobra R wheels and such have a 6.95" BS which yields 3.55" from the hib face to the outermost part of the wheel. If you are putting a 10.5" wide wheel on the car you will want to stay between 6.75 and 6.95 MAX to avoid clearance issues. Just remember, the 6.75 moves more of the wheel to the outside of the car (to the fender) and the 6.95 tucks it more underneath the wheel well. If you get into running 28" high tires, you will want to find out from others EXACTLY what BS is the best fit as with the 6.75 it may or may not hit the fender, and with the 6.95" it may hit the inner fender, quad shocks, etc. This info is all for a 10.5" wheel but it can be applied to any size wheel. For example on a 7" wheel you can have as little as 3.25" of BS and it will still fit in the wheel well but it'll push the tire out to the fender. Just remember that you want the value from the axle hub to the outtermost portion of the wheel to not exceed 4" MAX and the BS can never exceed 7" MAX and you should be Ok with the fitment depending on the size of the tire. When I say MAX I mean MAX... I wouldn't get too close to the numbers. To be on the safe side I personally wouldn't do much more than 3.75" max from the hub to the outer portion of the wheel and 6.9" of back spacing.
i want to get new wheels and slicks. strickly drag wheels. like welds or something. only going to be used at the track, never the street.
i guess i should clarify what i mean by cheap. i don't want something that is NHRA top fuel quality, but i don't want a complete piece of crap either. just something that is i guess cost-effective. the best bang for the buck.
Bang for the buck you are stuck with the normal wheels like the weld pro-star & drag lite, Centerline convo pros, tel stars or warriors. I LOVE warriors and no one runs them. If I didn't already have bogarts and was in the market for a nice drag wheel, I'd opt for the warriors.
Welds can be had on the cheap. Draglites are light and cheap. Prostars look better in IMHO. I run an 8" rear 3.5" front also on the track only. The fronts and rear require longer studs. And a spacer in the front (personally I don't like spacers). That adds a bit to the cost.
I don't run skinnies on the street.
I picked up my used prostars for 600 shipped with skinnies/ET Streets and lugs. I took my full slicks from my draglites and put them on the prostars.
I have seen sets of draglites for 400-500 with tires.
