When I open a datalog in EEC Analyzer it gives me an error....how to fix??
When I open up EEC analyzer and hit open in the datalog section I get this:
The connection was not valid. The Paradox file name can not be opened. Microsoft has a know issue with Parafox file path lengths. Make sure the path to the Paradoc log file is less then 65 characters in lengt, then re try opening the datalog.
What does that mean? Am I doing something wrong?
This means you have your datalogs down too deep.
Probably something like
C:\Program Files\STKR 1.30A\LogFiles....and so on. (this example is 36 characters..)
If there are more than 65 characters (spaces count) in the path, it will have a problem opening them.
Move (or copy) them somewhere else. I always copy mine to c:\logs, and run EEC Analyzer on them from there...
Dennis
Dennis
Hey Dennis
Haven't seen you in a while! :D
Where you been hiding? :shrug:
Grady
Lets see. My wife had the inside of one of her tires were out on her 540 a couple of weeks ago. Had to go rescue her (I'm currently a stay at home dad.) Had to go get a whole new set, cause that's how I am. Then 2 days later she the corner of a box spring with the RIM (but missed the tire...), which BENT the rim. They were non stock rims AND out of production, so I had to go rescue her again, AND get the rims replaced. Then getit all aligned. Then she took vacation, and we went to Disneyland with the girls (ages 2 and 3) for 3 days. Got home, and that night the 2 year old started puking. Then I started the next day, the 3 year old the next, and finally my wife. It was Tuesday before I gotback to my routine. I usually get to post in the mornings when the 3 year old is in school, and the evenings if my wife is doing homework (Masters...). So, it's been a busy couple of weeks.
I plan on hitting Sacramento Raceway Saturday for a couple or three passes to see what I got (No slicks, just street tires). Assuming I can get the driveshaft out to change the U-joints before Saturday....(I already did a search. You said HEAT, which I can do...)
Sorry for the hijack....
