When it rains it pours!
89SportVert
283
Vancouver, WA
Ok now the motor seems to of picked up a vibration. It starts just off idle, maybe 750rpm through about 1200rpm. Does it in gear or out, moving or not. Anyone got any ideas on this? :mad:
I think the best solution to my other problem is to have some sheet metal welded to the floor for support and bolt the chair down through the floor and call it good.
Just got to find someone to do this.
Later John
time only said:
Harmonic Balancer or Motor mounts ??
Could still be harmonic balancer but mounts appear to be fine, no excessive motor movement when throttle is thumped.
ZeroCool said:
Mine was doing the same, check the crank bolt..
It was both in place and snug.
I noticed that the cooling fan had a serious wable. Could this cause the whole car to vibrate like that? :shrug:
Thanks for all of the help.
John
If the fan are out of balance it will cause a bad vibration,It was a first hand experience on my part. Just like Stangmen393 said,just take the fan off and start up the car,you will know right away if thats the problem.
The stock crank bolt on my car fail after like 90,000 mile allowing the balancer to moved forward,destroying a very expensive Black Magic Fan. Luck is with me that day since I was in heavy traffic at the time and was only doing 10-15 mph. It will be bad if I were at highway speed.........
Good luck in your search !
K.
Yellowmustang52 said:
Lost my HB last year. I was told that it's a "typical" problem. Mine separated, and destroyed the starter wire that is routed, imo, too close to it. Stock replacement is about $120 i think.
When I had the HB pulled out to replace the crank bolt,there was already a hair line crack on the snout of the stock HB,so I get to it just in time ( Now I had a SFI-18 spec HB and ARP crank bolt on the motor ). I was there when a friend in his 10 sec S/C Mustang had his HB comes apart in a hard launch couples of years back,luckly most of the pieces went down toward the track surface and not up into the hood or cut a tire.
89sportvert,Sorry for the thread hijack.
K.
