... porting jobs
Where can I send my stock crappy heads to get ported. I called DPM in cowansville but they said $1000 just to remove the thermacular (sp?) bumps. There must be a cheaper place, can it be done for around $300??? I just want to remove the bumps, I will attempt to do it myself. For $1000 I will take a week off work and grind the mofos down with a dremel, even if it takes 80 hours LOL
The valves, springs, and rockers are like new I would just re-seat them maybe? Anyway any advice... Right now I am thinking of just leaving them as is until I buy new heads (head cash went into a 48" HDTV
). Right now all that is changed is a HV oil pump, new timing chain assembly, Comp cams (I think only .500 lift), lifters. I am getting a Edlebrock performer intake and a 600cfm double pump carb. That should at least take my 351 stronger than a stock 302, even with the stock heads.
Right now I just want the car on the road and running, NEXT winter will be time to spend real cash on the engine. Besides I'm coming out of an 18 second beast so even a 14 second car will appear super fast to me.
Where can I send my stock crappy heads to get ported. I called DPM in cowansville but they said $1000 just to remove the thermacular (sp?) bumps. There must be a cheaper place, can it be done for around $300??? I just want to remove the bumps, I will attempt to do it myself. For $1000 I will take a week off work and grind the mofos down with a dremel, even if it takes 80 hours LOL The valves, springs, and rockers are like new I would just re-seat them maybe? Anyway any advice... Right now I am thinking of just leaving them as is until I buy new heads (head cash went into a 48" HDTV
). Right now all that is changed is a HV oil pump, new timing chain assembly, Comp cams (I think only .500 lift), lifters. I am getting a Edlebrock performer intake and a 600cfm double pump carb. That should at least take my 351 stronger than a stock 302, even with the stock heads.Right now I just want the car on the road and running, NEXT winter will be time to spend real cash on the engine. Besides I'm coming out of an 18 second beast so even a 14 second car will appear super fast to me.
