Where did you install your wideband oxygen sensor?
Passenger side 12 o'clock position about even with the front edge of the door. So its easy to run into the car because there is a grommet just underneath of the seat that will allow access for the wiring.
Generally speaking…it seems that the extra price does not justify the benefits (unless you can tune each bank individually). I do believe that the left bank is the one which will typically run lean first anyways. If you plumb the wideband to the lean bank, the other will only run slightly richer (more safe).
