WHERE IS THE CORRECT "FULL" MARK ON THE OIL DIPSTICK?
With 5 quarts and a filter change mine is right on the top of the crosshatched area. Plenty of people on here have dipsticks that are no right though so just put five quarts in and a new filter run it a few minutes give it a few minutes to drain back down and remark if need be.
I never put any oil in the filter, but I always oil the gasket. On my old covertible, at five quarts the oil level would be way over the FULL on the stick. Even after running the car. On the LX five quarts puts it at the FULL.
BlackFox5.0 said:
My car takes about 6 quarts including the FL-1A filter :shrug:
If the level is halfway down the crosshatching, then it needs half a quart. if it's below it, it needs 1 quart.
You're overfilling your engine. The dipsticks on quite a few of these cars are wrong. The fill amount is 5 quarts including the filter.
The reason it is a good idea to put oil in the filter, I believe is because that is where your engine first goes to take oil from. If you don't put any in there, it usually cranks a bit longer to get the oil going throughout, and that could lead to engine wear. I don't know for sure, but I have heard that from many people.
You are exactly correct. Always fill the filter before replacing or else when you start it - its first 5 seconds will be a "dry suck" giving your engine a very stressful time.
