Where to Find 12V Power Under the Hood (Drivers Side)?
sc95gt
23
Looking for a switched source for 12V on the driver's side - need at least 10 amps as I will be tapping this source to run my Snow Performance pump...
I saw a write up for the Snow kit on an '03 Cobra using the ABS circuit to provide power - is a '94-'95 ABS harness the same?
The underhood fuse box is right there. It's a great place to stash a SPDT/SPST relay for your pump. You'll use battery power for the pump itself and use a tiny amount of power (250 mA or so) from whatever control circuit you desire to energize the relay.
That's how I'd do it. Otherwise, for a straight circuit power source, perhaps you don't use an OEM circuit anymore and can pirate from it. Here's a diagram (courtesy of S&2B's [site host] and TMoss [diagram author])
http://www.veryuseful.com/mustang/tech/engine/images/Mustang-94-95-Underhood-Fuses.gif
Good luck.
Good luck.
Thanks for the info - think I'll use the rear window defrost circuit - poor defroster hasn't worked in years...
