Where to go next
  • Thread starter Thread starter amick5
  • Start date Start date Feb 21, 2006
amick5
Port Richey Fl.
Feb 21, 2006
  • Feb 21, 2006
Recently purchased a 1990 5.0 LX Hatchback from the original owner.We;; I stole it from him really.I have done some minor things with it like: removed the cats and installed off road H pipe,new catback flowmaster system series 40, cold air intake from K&N, removed coolant hoses from throttle body(not really cool now is it). I want to change the factory headers out and put hookers on it but not to sure.Stepped up the rubbers and kept the original turbine rims on it i put 245/60/15 on the back and 225/60/15 on the front.Any advice is welcomed.
89white50
440
central MA
Feb 21, 2006
  • Feb 21, 2006
gears! then maybe intake, throttle body, MAF, injectors with heads and a cam?
amick5
Port Richey Fl.
Feb 21, 2006
  • Feb 21, 2006
worried gears are going to send the rpm's way high in lower gears .Is this so
bryce93lx
88
Luke AFB AZ
Feb 21, 2006
  • Feb 21, 2006
If you have 5sp then no worries, slap 3.73's in and don't look back, lots of auto guys use those too, i went 3.55(with auto) just to drop it a few hundred rpm, but dollar for dollar there is no better upgrade
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Feb 21, 2006
  • Feb 21, 2006
How much is done to the car already? If it's stock and you are looking for a place to start, you can choose to follow this list:
First mods should be as follows (my take):
In order of Priority
1) Subframe connectors (SFC's) full length ones are prefered for a stiff chasis
2) Gears: 3.73:1 or 4.10:1 seem to be the popular choices
3) Full Exhuast (headers, hi-flo cats, catback +mufflers)
4) Buy a K&N panel filter (no CAI kit required) and put it in the stock box
5) Bumped timing to 12 - 14 degrees (free mod) 10 Degrees is stock.
6) Larger MAF, TB (MAF cars from 1988 california only, 1989-1993)
7) 3G alternator upgrade / electric fan
8) Fix the weak brakes
Optional MODs:
9) Strut tower brace (necessary on Convertibles IMO)
10) Underdrive pullies (they can't be used on S/C motors and cause charging problems)
11) Weight reduction out of the nose of the car
12) Shocks/Struts and lowering springs
13) C/C plates if you lower the car
14) Short throw shifter (if you have a manual transmission)
After those (the basics), it's pretty much up to you. There are plenty of Super Chargers or Heads, Cam and Intake packages to choose from.
Also, don't forget about the basic tune up
1) Changing all of the fluids (oil, coolant, trans, rear end, brake and some of the power steering)
2) Plugs: (non-platnum type) Autolite or Motorcraft are prefered
3) Oil filter: Motorcraft or equivalent (not FRAM)
4) Air filter: see first mods item #4
5) Plug wires: Ford Motorsport (FRPP) 9mm units are great
6) Cap / Rotor
7) Oxygen sensors
Quoting someone very smart "You need a good foundation before building the house"
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Feb 21, 2006
  • Feb 21, 2006
Lemme guess? JR, huh?
srothfuss
Oct 17, 2004
1,796
Woodward Ave.
Feb 21, 2006
  • Feb 21, 2006
You read signatures also....
M
  • mnky99
  • Sep 5, 2025
mnky99
M
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
Progress Thread "Alter Ego" White 1993 LX 5.0 5spd
  • idareu
  • Sep 9, 2024
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 19, 2025
idareu
For Sale 3-owner 1987 Mustang GT, $18K obro, Lancaster CA
  • Bill Cool
  • Oct 6, 2024
2K
Fox Body Mustangs For Sale (1979-93) Oct 13, 2024
nickyb
My 93 4v Fox
  • OffspringChaos
  • Aug 30, 2023
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2024
bird_dog0347
