Where to lift motor from???
stang9gt
1,247
State College, Pa
I have the motor ready to pull, where should I bolt that chain to that is safe?? I pulled my other one from where the bell housing bolts and the alternator...I am pulling this one with the trans connected and I am not sure where to pull from...Can't do the exhaust manifolds cause the pressure will crack my valve covers....
white99gt said:
With the tranny hooked up.I used the two bolts where the alt went..And one bolt hole on the rear of each head..
The easiest way is using a tilter (which has 4 lift points) and really helps pulling and installing the motor/trans combo..
Just doesn't seem safe lifting all that weight from those wholes in the aluminum heads...
