Where to read timing marks???
  • Thread starter Thread starter onebad7up
  • Start date Start date Jul 1, 2006
onebad7up
97
Nashville
Jul 1, 2006
  • Jul 1, 2006
I just got a new timing light and I am trying to set the timing on my 90 5.0. I stood on the passenger side and shot the light down at the crankshaft pulley but I didn't see anything. Where would I read from? Usually there are marks that tell the degrees but my car doesn't. Am I looking at the right spot?
Bladez5_0
460
Goose Creek, SC
Jul 1, 2006
  • Jul 1, 2006
You may need to get some sandpaper and sand the outside of the crank pulley. Mine had some light surface rust and you couldn't read the marks at all. Kinda thought about trying to do it with the car running but that just felt like a "Hey ya'll watch this" kinda thing. It takes maybe 5 minutes to sand the pulley. I think I used 400 grit.
TheBocSez
652
Converse, TX
Jul 1, 2006
  • Jul 1, 2006
I used a White Paint pen and a bright orange paint pen I bought at a crafts store. I marked TDC with the white and 14* adv with the orange. Much easier to see.
Jack the car up and crawl under (it easier from the bottom). Find the lines on the balancer and mark them. They may not be totally accurate because of outter ring slipage but it will help.
Also, just want to make sure you removed the spout before you attempted to time it. Also, you said you pointed it at the lower pulley. The timing mark is on the balancer. I know, simple things, but sometimes they are the ones that get ya.
onebad7up
97
Nashville
Jul 1, 2006
  • Jul 1, 2006
Once I fill in that dipped spot with white pen what do I line it up with? I see that little piece of metal with a whole in the bottom and then a pointed area at the top. Am I supposed to line that white line up in that circle?
TheBocSez
652
Converse, TX
Jul 1, 2006
  • Jul 1, 2006
No, with the edge of the top flat part that extends out a little.
onebad7up
97
Nashville
Jul 1, 2006
  • Jul 1, 2006
Okay. I just got an old Mac gun with the advance knob. Do I just set the knob to 13* and then line that mark up?
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Idler pulley as substitute for Power Steering Pump ?
  • Bhenders
  • Jul 15, 2026
  • Other Auto Tech
Other Auto Tech Jul 16, 2026
LILCBRA
Timing chain, guides and tensioner installation (Possible orientation in Intake Stroke)
  • StallionMax
  • Sep 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 24, 2025
StallionMax
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
