Wheres the heat?
ninety2.3
186
PA
I was driving my car for awhile the other day and noticed I was not getting any heat blowing out of my car. I looked at the temp gauge and it was boucing around between the first and second mark past 130 degrees (somewhere around 160 or 180 im guessing) but never higher. I even let it sit in the driveway for 5 minutes after driving it for an hour and it never rose above that mark. Does that mean the thermostat is broken or is the heater core broke or something? I need to get it fixed cuz its freaking cold out. Thanks.
kiddiccarus said:
dude I am in the same boat on that one. I have a eater gore in the garage but I have a 93 ith A/C and the swap is goint to take 6 hours plus. Question, do you smell the tell tale maple syrup odor?
No I dont smell anything. I know that smell from other times but I def dont smell it now.
6 hours plus????
I know I'm crazy but I did mine in under an hour without taking the dash out. I worked through the glove box.
I'm betting that you did the core on Amanda's car, 351....the a/c cars (might be a '91-up thing too) are pretty much impossible to get at through the glove compartment, or so I've heard.
Ash
The non a/c cars you pull the glovebox out and there is a panel with several bolts on it. You undo the heater hoses under the hood at the firewall and pull the access cover off the heater core and its right there.
On a/c cars you have to dang near uninstall the dash to get the heater core out.
My 90lx rarely gets to the halfway mark,I changed the t-stat and installed
a new radiator(it needed one anyway)I've had it to the 1/2 mark and a
little beyond a time or two but the temps were in the 90's and the a/c was running.
So..no they don't heat up very well... :shrug:
but then,I don't drive mine in the winter.
do the thermostat first. i just replaced mine today. had the same symptoms no heat in the cab. i put in a new one. and it's now a blazing furnace. just don't drop the bolt so it falls inside the pulley it's very hard to get out.
Do you have any other tips or suggestions I should do?
do the thermostat first. it's like 7 bucks. if that solves your problem awesome. if it doesn't well you are only out 7 bucks. i would be willing to guess it's the thermostat because your temp gauage is wacky. bad heater core wouldn't affect the temp gauge.
I have the same problem, car WILL NOT heat up.....I changed the thermostat just recently and got a new rad last summer, but it still wont get up past the first notch in the winter. :mad:
A few weeks ago it was really really cold in the morning before school, like -45ish (Celsius) with the windchill (only about -28 or so without wind).....I go out to start my car, starts no problem, so I let it warm up for 45 MINS before I go to school....so i get into it 45 mins later, and it's heated up to the second tick on the guage :rolleyes: It was kinda warm, but as soon as I got on the highway to get to school, the damn thing cooled right off again! :mad:
yea I always heard that these cars were not very warm in the winter, but still you would think that at least some hot air would blow out after 45 min or an hour... :rolleyes:
Ash
it is possible that its a 91+ thing, Yeah it was on amanda's car and her car has A/C. lol I never said it was easy but just that I did it. I'm getting tired of working on her car and leaving foot prints on the headliner.(i'd rather her do that.)
91redlxhatch said:
my car has the maple syrup smell when the ac is on... what does that mean??
make sure you have coolant in the system. One time the hose on our other mustang broke and coolant leaked out, and it smelled like the syrup smell you are probably talking about. Just make sure you have the right amount.
