which and where to find an 03/04 rear driveshaft flange
Sicarius428
2,085
Hello guys. I posted this in 5.0 section but probably the wrong place to begin with. I am looking for the rear driveshaft flange that fits an 30/04 cobra IRS. This is one of the couple things I need left to get started on this project and don't know what type it is other than its larger than my old 8.8s and I need a different U-joint. I scowered the web for one and came up with only the rear end flange. I know I can pull the flange off my old 8.8 but much rather not compromise. Any thoughts or help is greatly appreciated. Thank you for your suggestions and time.
Kevin
still looking?
go to about any driveshaft shop,,the cobra uses a 1350 series u-joint instead or the common 1330 series.cost should be less than 50.00 also any ford dealer,infact the will most likely would be ceaper.should be a stock item
