Which cam?
  • Thread starter Thread starter Clienterror
  • Start date Start date Apr 14, 2006
Clienterror
22
  • Apr 14, 2006
Ok heres what I will have when I install the cam.
70mm MAF
Cold air intake
70mm TB
GT-40/Cobra intake
E7 heads that flow around 219/155 cfm (Good head job little better than GT-40's)
Long tube headers (1 5/8 primary 2 1/2 in collector)
2 1/2 H pipe no cats
2 1/2 cat back
3.73 gears
Ive got a T-5 tranny. I'm looking for something fairly agressive, perferibly not the 303e. I think the 303f might be a tad to big, Im leaning to the 303b because it has a somewhat agressive design. This car is daily driven but I don't mind any lope (Perfer a little actually). I dont mind getting another brand cam if anyone thinks there is a better choice. Are the mods above a good combo? Im looking for a high 12s low 13s pass streetable hoping I'll get it from this combo.
Thanks.
soontobefastfox
275
Troy, Michigan
Apr 14, 2006
  • Apr 14, 2006
call comp cams they'll point you in the right direction.
dragnazz5.0
My "0" key d0esn't w0rk, s0 I have t0 use the zer0
Nov 19, 2005
815
mooresville, nc
Apr 14, 2006
  • Apr 14, 2006
ive got the same setup that you have minus the long tubes and my heads probably arent nearly as good as yours are but i run the trickflow stage 1 with 1.7 rockers and its awesome. very nice idle and awesome power band
1SLO306
My 97 GTP owns you ALL!
Mar 31, 2005
904
Muhlenberg, ky
Apr 14, 2006
  • Apr 14, 2006
do this or go with the F cam/TFS stage 1 with 1.7 rockers. thats about all i would do until better heads and intake
aleborjas
610
  • Apr 14, 2006
dont get any cam from ford or crane they are not very good get TFS, Comp cams, or any other brand...
1SLO306
Mar 31, 2005
904
Muhlenberg, ky
Apr 14, 2006
  • Apr 14, 2006
do u have a vid or anything of ur car at idle. Im do basicly the same h/c/i except for a TFS intake.
i dont see y theyre not good. Alot of people have b,e,f,x,z cams in thier cars
aleborjas
610
  • Apr 14, 2006
nop i dont have any vid of my car at iddle, but my seats at 800RPM's with the a/c on and i don't feels the cam very rough and i love that cam it only turns 6200 RPM but is quick and its a monter on torque some friend of mines think i have nitrous because i flor my car on second and smoke the tires quick i realy love comp cams all there stuff are very good...
BlueRevenge
You will know wind when it escapes from my ass.
159
Washington State
Apr 14, 2006
  • Apr 14, 2006
I've had a b303, tfs stage 2 (in my truck) and e303 (now). Really don't like the ford cams after all these years. The TFS stage 2 is really killer sounding but you have to notch your pistons. Probably going to ditch the e cam myself in favor of something better one of these days. Blah, cam #3 for my stang.
Don't know if they're still around but my friend used to have your exact setup with a wolverine 1087 cam that really rocked.
aleborjas
610
  • Apr 14, 2006
70mm MAF
Cold air intake
70mm TB
GT-40/Cobra intake
2 1/2 cat back
3.73 gears
Thanks.
for your combo i'll run XE270HR-12 from comp cams #35-324-8 is the best cam i could find for your engine the cam card sais that it uses 1.7 rockers but i called comp cams and they told me that it works good with 1.6, you cant go bigger than that because of your heads and i dont think you have problems with your pistons because of you valve size....
ExplodingGopher
517
The mistake on the lake (Ohio)
Apr 14, 2006
#10
  • Apr 14, 2006
  • #10
all the 5.0 cams from ford are outdated, get a TFS stage1. Oh and BTW all ford cams aren't crap, i run an FRPP cam in my 466, very nice cam profile with a split duration and high lift.
Clienterror
22
#11
  • Apr 14, 2006
  • #11
Awsome, thanks alot for pointing me in the right direction I really appriciate it.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Apr 14, 2006
#12
  • Apr 14, 2006
  • #12
I think you should get a cam that fits what ever springs you're running and with in the RPM range your motor runs at. No point in putting a cam in a motor with springs that aren't going to take it.
C
Dyno day! # guesses?
  • clayton seiders
  • Aug 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 16, 2025
Scrapla347
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Fox 89’ GT 331 stroker, Trickflow upper/lower, TF#3 Cam, stuffed with forged goodies.
  • 08GT500
  • Nov 6, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 6, 2025
08GT500
