Which cam?
Clienterror
22
Ok heres what I will have when I install the cam.
70mm MAF
Cold air intake
70mm TB
GT-40/Cobra intake
E7 heads that flow around 219/155 cfm (Good head job little better than GT-40's)
Long tube headers (1 5/8 primary 2 1/2 in collector)
2 1/2 H pipe no cats
2 1/2 cat back
3.73 gears
Ive got a T-5 tranny. I'm looking for something fairly agressive, perferibly not the 303e. I think the 303f might be a tad to big, Im leaning to the 303b because it has a somewhat agressive design. This car is daily driven but I don't mind any lope (Perfer a little actually). I dont mind getting another brand cam if anyone thinks there is a better choice. Are the mods above a good combo? Im looking for a high 12s low 13s pass streetable hoping I'll get it from this combo.
Thanks.
ive got the same setup that you have minus the long tubes and my heads probably arent nearly as good as yours are but i run the trickflow stage 1 with 1.7 rockers and its awesome. very nice idle and awesome power band
aleborjas said:
dont get any cam from ford or crane they are not very good get TFS, Comp cams, or any other brand...
do u have a vid or anything of ur car at idle. Im do basicly the same h/c/i except for a TFS intake.
i dont see y theyre not good. Alot of people have b,e,f,x,z cams in thier cars:shrug:
nop i dont have any vid of my car at iddle, but my seats at 800RPM's with the a/c on and i don't feels the cam very rough and i love that cam it only turns 6200 RPM but is quick and its a monter on torque some friend of mines think i have nitrous because i flor my car on second and smoke the tires quick i realy love comp cams all there stuff are very good...
I've had a b303, tfs stage 2 (in my truck) and e303 (now). Really don't like the ford cams after all these years. The TFS stage 2 is really killer sounding but you have to notch your pistons. Probably going to ditch the e cam myself in favor of something better one of these days. Blah, cam #3 for my stang.
Don't know if they're still around but my friend used to have your exact setup with a wolverine 1087 cam that really rocked.
70mm MAF
Cold air intake
70mm TB
GT-40/Cobra intake
2 1/2 cat back
3.73 gears
Thanks.
for your combo i'll run XE270HR-12 from comp cams #35-324-8 is the best cam i could find for your engine the cam card sais that it uses 1.7 rockers but i called comp cams and they told me that it works good with 1.6, you cant go bigger than that because of your heads and i dont think you have problems with your pistons because of you valve size....
