Okay guys I am about to beat a dead horse again. I Know I know what are the best peformance heads for the 302 ford are the afrs. ANd I know that the performance levels go as listed in order:
1.Afr 185
2.trickflow twisted wedge track heat
3.edelbrock performer rpm
4.afr 165s
(3and 4 are pretty much even)
But my problem is I can get it into my head to spend 1400 for the afrs when I can spend that for thr trickflow heads with the matched cam and only lose 10hp. Which seems worth it because the heads and cam are ment to work together and will probally work better that the afr 185 with a off the shelf cam even though the afrs make more power. But then I run into my next problem I can get the edelbrock per. rpm total match set. the heads from edelbrock are only 1100. with that packagetotal I get a matched intake cam and heads. But with that set up it only puts me around 370 hp when all the other put me at 400+. Then I notice the victor jr heads that are 1200 and are beter that all the rest but they are less streetable in my mind. SO is it just me begin over bearing on the whole matched thing or is it really not extremely important with in reason. Alot ofwhat I hear is that even though there is less power with the matched setup it will work better but I hear that sometimes there is exceptions to the rule .I basicly need a push in the right direction and to be truth full I like the trick flow set up. But let me know What you think.
1.Afr 185
4.afr 165s
TFS
