Which Fluid is the BEST for the T5
  • Thread starter Thread starter 1993SSP
  • Start date Start date Aug 27, 2004
1993SSP
1,194
Ky
Aug 27, 2004
  • Aug 27, 2004
which fluid is the best for the T5 as far as smooth shifts and performance?? thanks!
HISSIN50
34
129
Aug 27, 2004
  • Aug 27, 2004
it is all personal preference. i did a lot of searching a few weeks ago and did not learn a lot. i could not find objective data, just opinions.
so ill toss out my two cents. i run Redline D4. in addition to my gut (i was running redline and considered switching), Adam had some compelling thoughts about it being good stuff to run.
good luck.
M
mooktank
237
  • Aug 27, 2004
Summit recommends redline D4 in the new T5Zs they sell. I personally could find any of the stuff so I got mobil 1 synthetic ATF. It's pretty good.
hotrodnut
672
North Florida
Aug 27, 2004
  • Aug 27, 2004
This may sound like a Ford "sin", but I have heard GM Syncromesh is good to use in the T-5. I use it in my 3650 and feel it has helped its notchy shifting a lot.
bmo37
2,368
New Jersey
Aug 27, 2004
  • Aug 27, 2004
thats what i have in my tko, you can actually buy a pennzoil equivelent called just plain synchromesh.
hotrodnut
672
North Florida
Aug 27, 2004
  • Aug 27, 2004
Hey, thanks for the pennzoil tip, the next time I change it I'll get that instead of the GM stuff.
stockhatch
536
polar sloth country
Aug 27, 2004
  • Aug 27, 2004
I used el-cheapo Havoline in mine and never had issues with smoothness...
AC
squeeeg
1,905
Michigan
Aug 27, 2004
  • Aug 27, 2004
Synchromech is for tremec trannys regular ATF or synthetic ATF is what i recomend
maverick0716
3,924
Chilliwack, BC, Canada
Aug 27, 2004
  • Aug 27, 2004
Tremec's use GM synchromesh because they have bronze synchros.....or something like that. I know they're different than T-5's and thats the only reason they use the Synchromesh.
I use Redline D4 in mine by the way.
HISSIN50
34
129
Aug 27, 2004
#10
  • Aug 27, 2004
  • #10
some guys on the corral like running synchromesh in their T5's. i personally would not, but they do.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Aug 27, 2004
#11
  • Aug 27, 2004
  • #11
I just run ATF fluid like suggested from the factory in my T-5...the quik-lube guys didn't believe me until they looked it up in their books that ATF is needed for my car...
I
igotyofire
774
Southern California
Aug 28, 2004
#12
  • Aug 28, 2004
  • #12
ive heard good things about the gm syncromesh b4 owning my ford, lot of honda guys started using it when i was back into the scene....heh and i dont see anything wrong with putting GM syncromesh in a T5, its not like Ford made they trans......same trans can be found in plenty of GM's so i dont see the problem. Ill probably be going with this unless someone here can show me somthing better i should use
maverick0716
3,924
Aug 28, 2004
#13
  • Aug 28, 2004
  • #13
Redline ATF D4. It's made for T-5's.
88stangmangt
2,332
Stafford,VA
Aug 28, 2004
#14
  • Aug 28, 2004
  • #14
i like amsoil and royal purple synthetic ATF......................
HISSIN50
34
129
Aug 28, 2004
#15
  • Aug 28, 2004
  • #15
so which do you like better, and how do they compare?
PNY PWR
522
Wichita, KS
Aug 28, 2004
#16
  • Aug 28, 2004
  • #16
I'd never use anything with the name Penzoil on it. I just changed mine with Mobil1 synthetic ATF. You'd be good with any quality ATF.
Proper Transmission fluid for a 84nwc t5
  • Sask84gt
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 10, 2026
Sask84gt
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
M
Drivetrain T5 Transmission Leak at Tailshaft
  • MDrisc
  • Jun 17, 2025
Fox 5.0 Mustang Tech Jun 18, 2025
AeroCoupe
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
