Sold my heads, want to change things up a bit. Thinking about the RPM heads for use with my Performer II with 2.02 valves, or the TFS heads (track heats or whatever?) but I'm worried about the TFS piston to valve clearance. My pistons are SRP's notched for reliefs, but I understand the TFS heads are a little touchy. Cam is comp cams NX264HR, only .512 lift but may switch to a XE274HR before it goes back together, this time with head studs stil running 10lbs of boost. I would also like to lower my compression ratio so input would be greatly appreciated along with head gasket thickness and selection.
THANKS
THANKS
