I am currectly building an engine right now, and everything is done except the intake. I'm stuck on what for intake to go with.
Heres the combo to help you figure out whats best for it.
306ci Forged Bottom end
11.5.1 Compression
Lunati Hydralic Roller Cam (242/252 Duration @0.050) (560/576 Lift)
1.6 Roller Rockers
AFR 205cc Heads (unported)
75mm Throttle Body
24lb injectors
I have a GT40 lower intake laying in my garage. I seen alot of "Box" upper plenums for the GT40. If I were to port-match the GT40 to the 205cc heads and get a box upper plenum would it make the same or more power over the trickflow R or edelbrock victor. This motor will be reving to 6500 + RPMS. I'm not looking for good low end torque, just an all out high horsepower screamer.
Also I heard that single nozzle nitrous systems at 150+ shots aren't effecient with a long runner intake. Would my nitrous system benifit from a Box upper plenum? It is a Nitrous Express Single Nozzle Wet System good up to a 300 shot.
11.5.1 Compression
1.6 Roller Rockers
75mm Throttle Body
24lb injectors
nough said!
