Which will give me a better 60'? A 275/50/15 MT drag radial on a 15x8" rim or a 315/35/17" on a 17x10.5" rim?
I think the 15" would probably give you a better launch. The bigger sidewall should help a little. As long as your running a low psi in your tires.
you're comparing a drag radial to a wide street tire?
go with the 15's
Theres a picture floating around somewhere of a guy with the 315 MT DR's and he was able to pull the front end way up on the launch so I think that the tire will only go so far and the suspension will eventually take over. Although the lighter wheel in the 15" sounds like a good thing.
